Help with a JL amp input voltage
Old Jan 12, 2006 | 10:06 PM
silvernole12's Avatar
I plan to use the stock bose head unit. Which setting will be correct for the input RCAs into the JL amp, high or low voltage?
Thanks
Old Jan 13, 2006 | 07:07 AM
jeremyp111's Avatar
That depends on how you decide to connect the amp. If you tap into the HU outputs before the bose amp then it should be set to low. If you tap into the amp output then it should be set to high.
Old Jan 13, 2006 | 11:24 AM
amthar's Avatar
Connect it before the Bose amp and use low voltage.
Old Jan 13, 2006 | 04:27 PM
I should of been more clear..sorry bout that. Yes I was going to tap the wires before the bose amp. So I see now that I would use low voltage. Thanks guys for the help.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
6spdGspot
Oct 5, 2015 01:55 PM
