New Audio System and Cruise Control Function
Old Jul 24, 2020 | 08:17 PM
G35ownersdad's Avatar
fully loaded
Okay Guys and Gals, I had a new audio system installed my my 06 coupe. At the same time I had a steering wheel control interface installed which permitted me to use the steering wheel controls the same as with my stock stereo system. The issue I am now facing is that my Cruise control no longer works and the cruise control "SET" light flashes....can anyone shed some light on why this might be happening?
thanks in advance for your responses
Old Jul 25, 2020 | 02:12 AM
05_SkylineSedan's Avatar
20 Year Member
There's a good chance it's NOT related to your new audio system as I think those steering wheel switches are a separate circuit from the cruise control switches. There are a couple fuses to check. (Are your brake lights are working ok?) Something else you can try; next time you are moving along fast enough to use the cruise control, carefully pull back on the brake pedal a bit with your toe and see if it will engage. There are two switches on the brake pedal (and one on the clutch pedal for a MT) which need to be working correctly before the cruise will engage. If there's too much play in either pedal it can bump your cruise offline.
Just a couple ideas.
Old Jul 28, 2020 | 02:05 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Could also be the clock spring, they're a known failure item in these cars.
Magic
Jun 30, 2013 12:37 AM
ontarget
Jan 26, 2011 07:07 PM
psheehan
Sep 22, 2008 01:49 AM
RockyR
Nov 9, 2006 07:38 PM
lololololop
Sep 25, 2004 11:30 AM
