Post Pix of Radar Detector Set Up
I have a V1 hardwired with a concealed display. I mount the V1 behind the rear view so that just the rear detector sticks out the side. I mounted the concealed display under my aftermarket GPS. That way people cannot see it from behind thru the window.
I also put in a button under the steering wheel to turn it off quick when needed. Reaching behind the mirror to turn it off was a PITA.
Kevin
Kevin
Originally Posted by MrElussive
![](Http://www.amirsaleh.com/Emile/Passport01.jpg)
![](Http://www.amirsaleh.com/Emile/Passport02.jpg)
how did you hardwire the power into the homelink power source? was it difficult to install? i've always read that the higher the radar detector placement on the car, the better the range/sensitivity. is that the case when the radar detector is place all the up near the rearview mirror?
Originally Posted by DHCrocks
pics of my hidden Blinder install...
two detector units in grill
![](http://img.photobucket.com/albums/1003/DHCrocks/blinder_17.jpg)
Thanks,
Igor
you need to trim the grill to get it to fit. check out my yahoo photo album for detailed pics.
http://pg.photos.yahoo.com/ph/cyohi/.../ph//my_photos
it's a stand alone units no interconnection with any other detectors.
