NEED audio and electrical advice/knowledge! '11 g37 non bose
Old Feb 17, 2021 | 04:18 AM
28Geez's Avatar
G37sedan.k&ntyphoon.invidiacatback.bullydog.+aesthetics
'11 G37 sedan journey non-bose
I just got my first VQ last month coming from always driving a mopar car/truck. And need some help and how to advice as well as what all i would need to buy for wiring and installation etc to meet my final audio goals setup. And possibly some help with the wiring diagram
1.install aftermarket HU
2. Install epicenter to run to the amps
3. i want to add a 4ch amp to push the 2 front door lower 6.5s i installed, and 2 6 6x9s ive added in the backsest in a custom pod i built to fit in the cavity thats created when the armrest is down. In addition to the 4ch i want to keep the stock amp to push the tweeters ive added in place of the front door upper speakers, and to also push the back door 6.5s i installed.
4. Add another amp for the dual 12" enclosure ive added to the trunk.
Old Feb 18, 2021 | 09:49 AM
telcoman's Avatar
Veteran: Army
Welcome!
Some things to think about.
1- How much money do you have budgeted for this project for a 10+ year old vehicle?
2- Are you planning too insure all of the additions to your insurance in case of theft or a total loss accident even if not your fault?
3- Have you considered the additional power load on your electrical system including the battery, alternator, current draw, wiring,and proper fuses to prevent overload and possible fire that destroyed the vehicle and all of the electronics? Remember the ECU in these vehicles do not like surprises and can put your vehicle into limp mode to prevent you from setting your vehicle on fire.
4- If you are not familiar with ohms law do a little research to compare the current draw of the stock Bose system vs what you are planning to install.
5- Perhaps you should talk to your insurance agent prior to proceeding and make a list of questions to ask.
Good luck
Old Feb 19, 2021 | 12:57 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Moving this thread to the A/V section.
@28Geez you will probably have better luck over at MYG37.COM since they deal exclusively with that platform. We're almost entirely 2003-2007 coupe, 2003-2008 sedan over here on G35DRIVER.
Kevin Ramirez
Sep 25, 2020 03:10 PM
vanharca
Jul 25, 2011 10:58 AM
Kidd1077
Oct 9, 2009 01:15 AM
paky786
Oct 25, 2007 01:43 AM
ballisticus
Nov 13, 2006 04:18 PM
