4080 box
4080 box
Anybody have a 12W6V2 in a 4080 box? if you do how does it sound? I'm running mine with a Q logic box and it sounds good but I want more trunk space... oh and I'm running a JL 500.1 amp with it.. thanks
The only box I sell for a 12" sub is for the sedan with the small spare tire. The trunk floor is raised up with 2" black styro-foam if you have the full size spare tire, this will only allow you to use the shorter 10" box. The coupe box is only avail. in 10" versions. Please PM for pricing.
Thanks, 4080
I would check if the wiring from the back of the box is in the way (you can move the box almost in position and then reach behind and feel for interference), or you have something under the carpet or under the black plastic cover where the bose amp is located...........if everything is in place it should fit perfectly
Originally Posted by jwarner
Last I checked, he charged $299 plus shipping. I haven't bought one yet, but I intend to do so.
Thanks, 4080
Originally Posted by nismoGcoupe
4080,
is it possible to port this box? if so what sub could we use ?
Due to the fact that the internal air space for one 10" sub ported would need to be about .75-1cuft., no. On top of that you would need space for the port itself. I have modified this box for one 8" ported, but it only required .8 cuft. The box with an 8" ported sounds awsome but not as much output/volume than a 10".
Thanks, 4080
Thanks, 4080
Thanks, 4080
4080, what is the volume of the 8" ported enclosure and what frequency is it tuned to? Thanks.
The internal air space volume is .85cuft. The two boxes that were built for 8" JL woofers were tuned to 32 hz.
4080
