Driver side speakers not working.
We replace the trannys all the time, its the clutches we charge for. Funny thing is, whenever a car comes in for a cltuch 9 times out of 10 we warranty the trans and slave cylinder, and charge for the clutch. When the customers come in we just park the car on the back lot and order the trans and clutch parts and so on, we dont even look at it because 99.99999999999999999% of the time its the same deal.
With a supercharger your now f-ed on any thing powertrain related. More HP, is more stress on the clutch, trans, drive shaft, u joints, rear end, and axles. Now that the engine is drastically modified you can forget check engine lights being looked at under warranty as well. Yeah, you do have it documented that the trans was grinding into 3rd, but I can garuntee you that nissan will argue that it was an intermitant problem that goes away with the break in period. But whos to say that they will even see the supercharger? When I do clutch jobs I dont even lift the hood, no need to. I can honestly say that its entirely possible that I have replaced the clutch on a superchargerd vehicle.
Id talk to the guy and see what he can do for you. Everytime the customer has tried to bargin with us we usually go along with it as long as its not unreasonable. Offer to pay for the labor if they can get the part warranty or somthing like that. The reason that they cant give you the part is that your not nissan/infiniti certified to work on a g35 so the quality of the install is questionable. If the part does fail later whats to say it is an actuall part failure, or bad install? Yeah, the line about being certified is BS, but it covers their ***.
Originally Posted by accordfreak
hey g35 mechanic, will i void my radio warranty if i changed my leds on the center console to a different color?
To be honest, I dont think ive even ever looked at the LEDs that light up the thing because im trying to think of how they are installed, but im drawing a blank. If you just pop them out and pop new ones in you should be fine, if you went and wired it all on your own making connections to the curcuit board then your more than likely screwed.
