Escort 8500X50 "Service required"
Old Apr 15, 2005 | 03:50 PM
ZMercman's Avatar
Purchased March 20th, my blue X50 detector has displayed a "Service Required" at least 5 times! A simple off/on will reset the unit until the next time. The folks at Escort are happy to oblige but has anyone else had a similar SES code come on there 8500 unit? All the connections are secure and the unit hasn’t fallen off the windshield because I made the aluminum bracket (which someone here made so I copied, Thanks ) and secured it with 3M double stick foam tape.
Old Apr 17, 2005 | 09:36 AM
prubio's Avatar
I've had my Escort Passport 8500 for 4 years now and just yesterday I started seeing the behavior you are describing. I will be calling Escort this week to find out what might be wrong and what it will cost to fix it. Did they tell you what might be wrong when you called?
Old Apr 18, 2005 | 12:10 AM
ZMercman's Avatar
They were confused also and asked me if the unit "self calibrated" after the "Service unit" display popped up. I said no and they were at a loss. They want the unit back for testing and replacement if necessary. Mine is only a month old so I'll continue to use it for a while to see if it gets worse.
Old Apr 18, 2005 | 07:37 AM
prubio's Avatar
After acting up all day on Saturday, mine worked like a charm yesterday on our return trip. I don't know what's going on...this is the only time it's ever done that. Yesterday, it did not even try to self calibrate. The day before yesterday, it would self-calibrate 3 or 4 times before kicking on the "Service Required" message. If you turned it off, it would go away, for about 15 minutes then come back. Weird...
Old Apr 18, 2005 | 08:22 AM
FL350GT's Avatar
one comment buy a bel r65 or valentine u cant go wrong !!
Old Apr 20, 2005 | 09:27 AM
JohnBoy's Avatar
I had the same problem w/ mine. Had it for about six weeks and then it started doing it every now and then. Then it became more and more frequent to the point that it wasn't usable. Luckily, I was able to return it for a new one which I've had for about 4 months now without any probs.
~John
Old Apr 23, 2005 | 12:30 PM
trebien's Avatar
Just for comparison, I purchased an X50 red around 4/21/2005 and haven't had any problems, yet...
Old Apr 27, 2005 | 12:14 PM
JD_AND_DA_G_RIDE's Avatar
Yeah, same here. I've only had mine re-calibrate only once. The regular 8500 didn't have the POP radar built in like the X50 did or so I believe. So, is it true that you can send the radar to Escort in to have it updated?
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
f22raptor
Mar 18, 2016 08:50 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
