NavBox Installation Help
Old Apr 22, 2005 | 11:26 PM
g35 squirrel's Avatar
When installing the navbox to my navigation do I need to splice into the harness behind the navigation screen, by the navi control unit, or both spots? I have it spliced in both spots. Now when i go to switch between navigation and xbox i see scrolling horizontal lines of the navigation map in the foreground. Much help appreciated. Thanks.
Old Apr 22, 2005 | 11:56 PM
GoSooners's Avatar
You only needed to splice behind the navi control unit, where the DVD-ROM sits; just 1 harness that you need to splice into. Did you follow the wiring diagram provided?
Old Apr 23, 2005 | 12:12 AM
yeah i followed the diagram, it looks like it was spliced in both sections. i'm gonna go remove the one behind the screen then. thanks.
Old Apr 23, 2005 | 12:23 AM
ok i removed the splice behind the screen and i'm still getting the scrolling map in the foreground of the xbox screen.
i have tried hard wiring the inverter to the power wires of the cigarette lighter
and plugging the inverter into the cigarette lighter with an adapter and it looks exactly the same.
any other ideas?
Old Apr 23, 2005 | 10:50 AM
g35driver05's Avatar
Is this a 2005 G35? What are you using for sound output?
Old Apr 23, 2005 | 12:06 PM
this is a 03 sedan. and i'm using a pac aanis for audio.
Old Apr 23, 2005 | 01:16 PM
ok so to t/s the current problem, i have my xbox being powered up from an extension cable going into the house. so i think this rules out a possible problem with the inverter causing the problem. i'm stilling getting those scrolling lines, so i'm going to redo the taps that i have into the harness behind the navi control unit. i've gotten a couple of pm's of people trying to help me out and i mus say that I appreciate it greatly.
Old Apr 23, 2005 | 02:16 PM
GoSooners's Avatar
I think you just spliced wrong. There are only 4 signal wires you need to cut. I guess it's not really a true "splice" since you actually cut wires from the harness. From looking at the diagram, your 4 sets of wires (wire XX, wire XX w/ stripe) coming out of NavBox would be connected accordingling to the 4 signal wires you cut from the harness.
I don't have the diagram in front of me but here's an example...
Say you cut red wire from harness. Your nav box has a blue wire and blue wire with stripe. Solid blue wire would go to the side of the red wire that goes into the harness. Blue wire with stripe will go into the other side of the red wire that's cut/separated. Then you have power, ground and switch coming out of the NavBox. Power: just tap into any remote power. I tapped into the big red power wire coming out of my PAC. Ground goes to chassis somewhere. Switch went to one of my switching wires on the PAC.
Old Apr 23, 2005 | 02:28 PM
ok i think i understand what your saying. basically the two sets of 4 wires would make a loop going through the navbox. i was under the impression that all i have to do was tap one set of wires into the existing harness and that would be it. i didnt understand that i would have to cut it and attach one wire from one set into one side of the cut, then the other wire to the other side of the cut.
so then the wire would look like this right?
-----|<(striped wire) (solid wire)>|-------[harness]--[nav unit]
my next dilema would be that all the wires look the same coming out of the navbox. i was confused with that as well. i dont have 1 red wire and 1 red/blx wire. they are both just solid red coming from both sets of the navbox. and thats how it looks with all of them. i just its just trial and error now.
Old Apr 23, 2005 | 02:45 PM
alright success!!! thanks a lot for the help gosooners! if your ever on long island i'll buy you a drink.
Old Apr 23, 2005 | 08:07 PM
Hey im glad u solved your prob! How about some pics of how u finally installed the wires. Im planning on doing for my G. Btw in my New Jersey. I would love to check out your set up . Where in Long island u from?
Old Apr 24, 2005 | 12:02 AM
GoSooners's Avatar
No prob, sorry I didn't get back to you earlier but you figured it out! I was out changing to Hawk HPS brake pads today. Brakes were starting to squeak and get mushy. How are you doing your switching? Did you connect it to the PAC negative outputs?
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
