Finally, Pics of my ENTIRE Double Din Conversion!
Old Apr 25, 2005 | 05:42 PM
tgenius's Avatar
So without further ado.. here we go:
A Full Vertical shot of my Dash:
A Close up of my Alpine 9835:
A Close up of Alpine 9835 at Night:
A Close up of the Alpine AmpLink settings for Mono amp like Voltage,Amperage, and Temp (lil out of focus, sorry! )
A CloseUp of Diamond Graphite Colormatched XMAntenna:
A Full Trunk Shot of the DG XM Antenna:
A Shot of the 4080 Sub box for the Sedan:
A Shot of the Amps (Mono on right) with 6CD Mp3 changer:
Finally, a shot of the distribution block I'm using to run power for the amps:
My Components are JL XR Components, I have a pair of Eclipse Coaxials for fill, and the sub is a JL 10W3v2-d2.
Opinions? Mind you, about 80 percent of this was done DIY between me and my old man (exception being running speaker wire/install of speakers) Even harsh criticisms are welcome, but anyone who went to the SFL meet 2 weekends ago loved it and that was before we put the mono amp!
Old Apr 25, 2005 | 05:48 PM
iLLG35's Avatar
NY G-Squad G Race Driver
Wow man lookin goooooooooood
Old Apr 25, 2005 | 06:38 PM
tgenius's Avatar
15 views and only one reply?
Old Apr 25, 2005 | 06:54 PM
jasonlee4180's Avatar
Nice!
It looks very clean, matches and all!
Did you buy some kind of adapter kit for the double din?
Old Apr 25, 2005 | 07:08 PM
tgenius's Avatar
just the standard one everyone buys from Japan. I gotta thank Godzilla for that, he had a black kit in stock when I bought it late 04'
Old Apr 25, 2005 | 07:11 PM
mark5's Avatar
very nice, how did you get the amps to stay up? i know there's no support behind the carpet
Old Apr 25, 2005 | 07:16 PM
tgenius's Avatar
used two pieces of 1/4 inch board (like used in countertops) there's actually two spots where you can use for support on each one (the bar goes diagonally) so believe it or not they are held by one screw (albeit VERY tightly against it)
Old Apr 25, 2005 | 07:19 PM
rrpnow's Avatar
looks hot...
Old Apr 25, 2005 | 08:37 PM
tgenius's Avatar
thanks everybody! I know the wires are a mess, I have to clean them up a bit.
I just wish I knew someone in South Florida who is good at tuning car audio. I could really use the help in fine tuning everything.
Old Apr 25, 2005 | 10:48 PM
GRider35c's Avatar
VERY NICE!!
2 comments:
1. nice 05 rear tail-lights!
2. you didnt have to mount the xm antenna on the trunk, did you?? i have my navi antenna on the front dash, near the passenger side, and it works just fine!
Old Apr 25, 2005 | 10:56 PM
blazinZ's Avatar
looks great, quility install..
where did u buy that double din from. if you dont mind me asking, how much was it.
i had my head unit from my old car, i wanted to put it in the G, but i didnt want to mess with the dash but yours looks good. was it easy to do..? sorry for all the questions but i wondering about this for a while.
Old Apr 25, 2005 | 11:25 PM
tgenius's Avatar
Originally Posted by GRider35c
VERY NICE!!
2 comments:
1)Thanks on the tails
2)I had it on my rear deck, but it kept cutting out. Putting it on the trunk actually doesn't bother me, and even less now that it's colormatched. The guys from colormatchedantennas are running a deal where first 5 (now 4 I believe) who get an XM Micro antenna colormatched for $10 off.. great deal to jump at!
Old Apr 25, 2005 | 11:27 PM
tgenius's Avatar
I bought the double-din from Godzilla back in December. You see, I had the forsight to see that the AC controllers would be a BITCH to find when I was finally getting around to doing it, so I bought them back then and just kept them waitin to pull the trigger.
Concerning the headunit, the CDA-9835, I WAS originally lookin at its' replacement, the CDA-9855, but the glidestrip instead of buttons just wasn't working in my opinion, I prefer real physical buttons.
In terms of difficulty, that all depends if you have Premium.. if you do, you need to (or know someone who does) solder the button off the old controller board and put it on the new one. If you don't have premium, you can overlook that step. The DIY guide that is around (docron wrote it) is top notch, every step is covered in detail. All things considered, it wasan't too bad, just pretty time consuming (especially since I had to run the RCAs, the Amplifierlink cable, the XM tuner and smart adapter, and the XM Antenna, plus a turn-on wire.) It took about 12 hours of work, but it was ALL worth it.
Old Apr 25, 2005 | 11:44 PM
etang789's Avatar
great DIY install...my pick of headunit as well for this car ...it matches very well...why did you choose Alpine amps and did u try to fit them in the stock Bose (blose) amp location?
Old Apr 26, 2005 | 04:11 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
lol.....
nice....did you get the sense of great accomplishment and satisfaction doing it yourself?
can you clean up and hide your wires? just a thought....
otherwise, very nice and you didn't scratch the dash!
doc
