Finally- Amp and Sub installed: Pics
Old May 1, 2005 | 05:37 PM
speedygp's Avatar
Lightbulb Finally- Amp and Sub installed: Pics
I finally got My amp and subs installed! I wanted to do something like the 4080 box, but I didn't want to buy new equipment. I have a Rockford Fosgate Punch 4 ch amp and a Rockford Fosgate 12" Phase 2 sub that came out of my WRX. I still an using the OEM Bose system, the plus is that the amp comes w/ a sub controller so I have total control of Sub by a ****. I fine tuned it today and it sounds perfect for my liking. The only draw back is no spare tire, but that's why we have Roadside Assistance!!!
Old May 2, 2005 | 12:24 PM
blazinZ's Avatar
Thats a very clean install...props
i wanted to get this done some time this weekend what exactly is needed to hook your amp to the stock head unit. did you just use some sort of adapter.. would you know how much it cost? does it take a while to do?
Old May 2, 2005 | 01:26 PM
speedygp's Avatar
Thanks, a friend of mine that does custom installs did the whole thing. It is actually 3 custom cut pieces, the center housing the amp and sub box, the side pieces keep it clean and snug. Makes it easier to take out if I need to. Yes he used some type of adapter, but I am not sure what kind.I actually use the thin mat right over this ( not the heavy G 35 Accessory carpet ) this way I still can use my trunk to store things, and when I open my trunk it looks like I dont have anything!!! I will find out later today, and post up later!!
Old May 3, 2005 | 05:16 PM
05GRide's Avatar
Nice, clean install. I assume you measured out the space that's available in that spare tire area for a sub woofer box? If you have that measurement on hand that would be great, shoot me a PM. I had a 2002 Trailblazer that I did a huge stereo install in before my G. I had a Shocker Mouse 15" that needed a 5 cu ft. ported box (GIGANTIC). I also faced my sub upwards. But i found that it hindered me putting anything over it my trunk so during the travel of the sub the surrounds wouldn't be damaged. How has your (and our already small trunks) trunk faired with that limitation?
Old May 3, 2005 | 10:56 PM
speedygp's Avatar
I didn't do any measuring , but my friend did, my 12" RF Phase II needed 1 cube of airspace. He said I had plenty of room. As for the sub facing upward I covered it w/ the factory mat, w/ no problems at all. I am going to make a custom ring and cover for it soon though for extra protection. I actually still have the use of the factory cargo net, and I dont really have any gripes otherwise. The trunk is small anyways, thats why I did away w/ the spare tire!!!!
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
9tray turbo
Sep 29, 2015 10:22 PM
