Burning MP3s tips needed
Old May 10, 2005 | 04:22 PM
harley01's Avatar
First off, I have a 2005 G35 stock stereo. What program do you guys use to burn MP3s? I tried burning a CD-RW using Toast and when I put it in my stereo it could not read it. Can I burn MP3s to a CD-R instead....I have quite a few more of them. I tried to use Itunes to burna MP3 CD, but gave up. Do I need to create folders for Toast or can I just drag and drop a bunch of MP3s in the audio window.
Old May 10, 2005 | 04:30 PM
speedgeek's Avatar
Hi,
I use Nero. Basicly you just drag your MP3's, folders and all to the cd. I'm using cheap *** cd's and they read fine. You should burn the cd's as data cd's not audio or mixed mode. Hope this helps.
Old May 10, 2005 | 04:32 PM
dubs's Avatar
can the sock g35 play mp3..or do you have to convert them to a cda format??
redwillow's Avatar
20 Year Member
Cd-RW will prob not be recognized. CD-R's will work though.
Try: NTI CD maker or Roxio.
You should be able to just copy the .mp3 files to the cd. Make sure you are creating a data CD and not an Audio CD, so the files are moved as .mp3 data files.
Old May 10, 2005 | 04:35 PM
FrizzleFry's Avatar
i believe you also have to remember to finalize the CD
Old May 10, 2005 | 04:57 PM
Espresso's Avatar
I just made a CD full of mp3s and used Nero. Like mentioned above, just create a data CD with folders. The folders help sort your music so you don't browse through 100+ songs to find the one you're looking for. Now all I need to do it figure out how to turn on the song tags to see what I'm listening to.
Old May 10, 2005 | 05:10 PM
R8D G's Avatar
Florida G35 Club, Premier Member
For CD-RW you need to finalize the disc in order for it to be played. I don't have a G yet, but my corolla can play CD-RW, so I'm pretty sure the G can also.
Old May 10, 2005 | 05:15 PM
G6MT's Avatar
G'z 6MT
From: Mo-town(Modesto) Bay Area (Silicon Valley), CAL
Nero is the easiest way and cheapest way to do it.. Good recommend
Old May 10, 2005 | 05:31 PM
speedgeek's Avatar
When buring, choose the Write Method "Disc-at-once/69" it's from the pulldown menu on the burn screen. The inyour G just hold down the DISP button.
Old May 11, 2005 | 08:47 AM
harley01's Avatar
OK....thanks for the tips. I was able to get several CD-Rs burned last night with a good library of MP3 files. Sweet.
Old May 11, 2005 | 09:03 AM
Weeva!'s Avatar
roxio or nero w/cdrs
Old May 12, 2005 | 04:26 PM
harley01's Avatar
OK, i thought I was good to go, but then I played the CD. It only plays the first 4 folders and I have about 12 folders worth of stuff. Do i need to put everything in 1 folder or create subfolders within the first 4 folders?
Old May 13, 2005 | 12:45 PM
BlackGSedaN1027's Avatar
Try putting them all in one folder.
Old May 13, 2005 | 04:49 PM
bstrain74's Avatar
has anyone tried burning mp3's to a dvd disc and then playing it in your car? i dont get my G35 for a few weeks so I cant try it yet but I will.
Old May 26, 2005 | 02:55 PM
I beleive it won't read a DVD...not 100% though
