Sirius Satellite Radio Windshield Mount Antenna
Old May 16, 2005 | 05:51 PM
rupdog326's Avatar
Out of many - one people
Talking Sirius Satellite Radio Windshield Mount Antenna
http://www.grubbsperformance.com/Mer...=G35SedanAudio
Old May 16, 2005 | 07:48 PM
wnpublic's Avatar
Yup, I've had mine for a couple of weeks now. Works great.
Old May 16, 2005 | 08:30 PM
R8D G's Avatar
Florida G35 Club, Premier Member
Three Questions:
1-Can this also work with the coupe?
2-Can I see some pics of how this thing is mounted?
3-What else do I need to buy besides the antenna...The coupe I ordered did not have sirius installed.
Thanks
Old May 17, 2005 | 12:37 PM
West Palm 35's Avatar
I installed the sigma after my tint installation casued interference with my antenna on my rear deck. Did not want to install an antenna on my roof. Works great so far (about a month). Only issue was the length of the cable (which was insufficient to reach the receiver in the trunk). I bought the Siruis 50 foot extension (which was too long but the only extension I could find). The extension is a larger coaxial which makes it much more difficult to tuck and run to the trunk.
Old May 17, 2005 | 02:20 PM
wnpublic's Avatar
Originally Posted by geioushi
Three Questions:
Thanks
1. Yes
2. Yes
https://g35driver.com/forums/showthr...ghlight=sirius
3. It depends. If your coupe is 2003.5 or later (I think that's the cutoff), you have the wiring harness preinstalled. You just need the antenna and the receiver unit. If you don't have the wiring harness, you've got to get that and install it.
Old May 18, 2005 | 09:08 AM
Beowulf's Avatar
I have my sirius antenna with metal plate on the rear deck; It works perfectly, but I don't have any tint atm.... how big is this antenna? Its hard to tell from that pic... Sounds like a big PIA to run the wire from the windshield to the trunk...
Old May 18, 2005 | 03:26 PM
wnpublic's Avatar
If you're happy with the mount on the parcel shelf, why bother?
It's not difficult to run the cable to the trunk if you do a rear windshield mount - just tuck it around....
Old May 19, 2005 | 01:47 AM
Gs_G_Ride's Avatar
I have a 04 coupe with XM and I have the antenna mounted in my brake light..no problems...works great
Old May 20, 2005 | 10:30 AM
n1lul's Avatar
My entire sat installation took 45min. using the window ant. mounted in the center of the rear window. The wire run is a peice of cake: just tuck it in the head liner, pop off the cover on the passenger side "B"(I think) pillar and run it through the hole right into the trunk. Pop the cover back on and you are done.
Ray
Dallsinghjr1
Sep 17, 2023 11:25 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Claudiu
Sep 26, 2015 01:04 PM
