SAT, Install it yourself, tip # 2.
Old Jun 3, 2003 | 03:58 PM
Ca_Kid's Avatar
Even though the wires for the SAT antenna are small, the last thing you want to do is use a screw driver to stuff the wires under the rubber trunk molding. You run the possibility of nicking the wire, or even causing a break by using a screw driver.
The following pictures show how you can use a tool that can be purchased at any major drug store. It is called a gum stimulator, and is manufactured by the Butler Co, #600 and costs about $3.50. It really works, and the rounded edge can be used to stuff the small antenna wires under the rubber molding.
803G35c/C_Blue/Willow/6AT/Premium/Splash/Garmin SteetPilot III/V1/SAT/XM
Old Jun 4, 2003 | 07:35 AM
lebushaw's Avatar
Re: SAT, Install it yourself, tip # 2.
"kewl"
Larry Bushaw - "There's nothing a donut won't solve!"
04G35NYC
2nd Gen (V36) Sedan
Sep 13, 2015 02:56 PM
TinoNT
Sep 2, 2015 12:35 PM
FRUG35
Aug 31, 2015 02:33 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
