Mounting location for KNA-DV4100
Old May 23, 2005 | 02:00 PM
SagiSRP's Avatar
wondering if anyone has installed this and where did they mount the unit at? Would it fit in the top glove box where the stock nav unit goes?
Old May 23, 2005 | 02:59 PM
god_of_cpu's Avatar
StreetDeck.com Developer
If its a single DIN unit less then 7" in depth, it can be mounted in the digitalwheelz single din converter http://www.digitalwheelz.com/G35DinConverter_About.htm and put in the upper glovebox.
Old May 23, 2005 | 03:58 PM
SagiSRP's Avatar
these are the dimensions:
dimensions: 6-5/8"W x 2"H x 7-11/16"D (navigation unit);
Would it fit and how much does this cost? Thx
Old May 23, 2005 | 04:42 PM
god_of_cpu's Avatar
If its 7-11/16" its going to be too deep to fit in there. A metal bar in the back center of the upper glove box will block it for sure. The bar looks related to airbag system in some way so I wouldn't recommend cutting it.
If your not set on the kenwood unit, check out g35bob's installation that used a smaller pioneer nav system at http://mr2bob.com/G35.htm
Pricing can be found at the digitalwheelz store http://www.digitalwheelz.com/ecommer...alog/index.php
Old May 28, 2005 | 11:18 AM
JohnBoy's Avatar
I have the KNA-DV3100 which I assume is the same size. I mounted it in the upper glove box where the factory nav goes and it fits well. I also mounted the antenna in the factory location behind the clock and it works well.
~John
Jessica Ayoub
Oct 17, 2015 02:01 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
boostelevator
Sep 9, 2015 05:56 PM
pasjr1972
Sep 1, 2015 10:17 PM
