Poly-Fil in Box
Old Jun 8, 2005 | 11:53 AM
magnetism80's Avatar
Poly-Fil in Box
Hey fellow G audiophile I read on Crutchfield about this stuff called Poly-Fill for use in a sub box. It's basically just polyester filling like the kind found in pilows. It claims the sound wave coming off the back of your subwoofer reacts with the air contained in the box. Poly-Fil stuffing slows down sound waves inside the box, making the subwoofer perform as if the box were bigger. I have a box that is just a little bit smaller that the recommended size.
Has anyone done this or at least know if it works? Also do you line the inside of the box all neat-like or do you just stuff it in the box
Thanks again as always
Old Jun 13, 2005 | 01:22 PM
So Know one has done this or heard of doing it? I take it it doesn't work then
Old Jun 13, 2005 | 04:53 PM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
I've used it. It works just stuff the entire inside of the box the more you put in the better, Basically it fools the sub into thinking that it's playing in a bigger enclosure, Well good luck, David
Old Jun 13, 2005 | 06:24 PM
amg35's Avatar
Florida G35 Club
Keep it away from the subs suspension and vented pole piece.
Picture Share
Feb 4, 2018 12:41 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
prinny
Nov 22, 2015 11:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
