D DIN A/C board parts?
Old Jun 13, 2005 | 11:08 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Just wondered if anyone attemped to source the parts for the dual zone modification,
instead of removing them from the original board?
I was just thinking it would be nice to leave the original board intact,
to put the HU back to stock when selling the car.
Old Jun 13, 2005 | 12:28 PM
InTgr8r's Avatar
Well, just to answer my own question.....
Just took the covers off the A/C board ('04);
- was surprized that the LED & term. resistor were factory installed!
- I have located a switch that may work (see pic)
the terminal footprint is the same & height.
it's a standard 4mm SMD switch, available at most electronic component outlets.
I found this one at Electrosonic in Toronto.
The J-hook type, would be the right contact shape.
I'm going to pick one up in the next few days, I'll post my findings when it comes in.
FWIW;
After looking at the board I would recommend a hot air soldering tool,
instead of a normal iron.
This will prevent potential heat damage to the rest of the board.
Old Jun 13, 2005 | 12:52 PM
GRider35c's Avatar
well, if u dont have the SAT radio, take the SAT button off! you will never use it anyhow
thats what i did on my 04...
Old Jun 13, 2005 | 12:54 PM
BlackonBlackG35's Avatar
LED and resistor only need to soldered on the 05 A/C controller. Since you have a 04 only the button needs to be transfered.
Old Jun 13, 2005 | 01:23 PM
InTgr8r's Avatar
Thanks guys....
Never thought of the SAT button.
We buy parts for work from this supplier,
so I'll probably get one just to see if its the same.
WillisFL
Dec 29, 2016 08:56 AM
Frostbite91
Aug 20, 2015 07:20 PM
Frankieg35
Aug 15, 2015 10:49 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Rehman2009
Jul 27, 2015 03:23 AM
