Preouts 4v or 6.5v?
Old Jul 18, 2005 | 09:05 AM
mrb's Avatar
mrb
Preouts 4v or 6.5v?
Looking at a Pioneer Deck. The Pioneer version has 4V preouts, and the Premier version has 6.5V preouts? Should you always go with the higher voltage if the decks cost the same?
Old Jul 18, 2005 | 09:26 AM
tekknikal's Avatar
yes
Old Jul 18, 2005 | 09:44 AM
mrb's Avatar
mrb
Thanks.
Old Jul 18, 2005 | 10:04 AM
badtziscool's Avatar
Same price and feature set? Go Premire. I'm sure sq will be much better.
Old Jul 18, 2005 | 10:05 AM
mrb's Avatar
mrb
Anyone have a recommendation one way or the other on these 2 decks?
Pioneer DEH-P80MP
Pioneer DEH-P8MP
Old Jul 18, 2005 | 01:47 PM
Inno's Avatar
Go Premier DEH-P860MP
Old Jul 18, 2005 | 04:52 PM
tekknikal's Avatar
if you must go pioneer i agree with inno.
i went with the alpine 9835. not as easy to use but looks better and matches it with features.
Old Jul 18, 2005 | 11:38 PM
rcdash's Avatar
Ummm, one thought to add here. The higher preamp signal is good to maximize the S/N ratio BUT you can possibly overdrive the AMP's input stage. For example my infiniti 7451a 111Wx4 amp specifies a maximum input voltage of 5V. Anything beyond that I assume would be clipped or distorted. Of course that would be at higher volume levels only - but you are essentially limiting the volume range of your HU if you don't match it up well with your AMP.
Just make sure your AMP can handle the 6.5V range. The stock HU put out 2.2V. Most aftermarket decks put out between that and 4V. If you're not going to be driving through an AMP, then I suppose this does not apply and higher is better!
Old Jul 19, 2005 | 12:04 AM
Pearl05G's Avatar
That would all be dependant on what the amps are measured at during testing. My Arcs claim only 2.5Vmax tested @ 1Khz.Which easily accepts my 8V. Youll never see full output voltage unless your at full volume anyway.
If hes not using an amp at all than the preout voltage is complely irrelevant.
mrb: If your buying it legitly (ie: local store) than go for the Premier, the longer warranty may prove to be worth it.
