**** my xtant amp just fried
Old Jul 29, 2005 | 06:13 PM
FrizzleFry's Avatar
Man... just when you think you have everything going... **** happens. So I'm just driving home after my meeting this morning and my bass kicks out. I'm thinking wth? So I get home and check and the overtemp LEDs flashing. So ok... let it cool down for an hour. I hook it back up to try and nothing. Amp turns on ok. Things seem normal, just no output.
I know I can send it to Xtant for $120 to do the flat fee repair... but not sure I want to. This amp's 3-4 years old but it has one benefit, it matches my 4 channel. What to do.... I'm guessing it's a high power FET that went out. There's a slight component "explosion" mark on the PCB.
What would you do? Spend $120 to get it fixed, or say **** it and get 2 new amps. The reason I'm even remotely considering the 2 new amps is because of the size of these amps.
Old Jul 29, 2005 | 08:17 PM
rcdash's Avatar
It gets really hot in the trunk. My carPC sits in one corner and the on board monitoring reads the ambient temp as 50 degrees C when it's above 95 degrees F outside. I actually have a switched 12 cm fan exhausting out one of the side exhaust "ports" in the trunk. Without it the ambient temp used to rise to above 65 (that's Celcius - yikes!). Needless to say the CPU temp was above 75C and rising - not good...
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
JustinMKN1
Sep 18, 2015 03:40 PM
