home link!!!
Old Jul 30, 2005 | 03:14 AM
savefatkids's Avatar
home link!!!
i cant get this **** to work ive tryed everythinggggg maby its my garage or seomthing?? wtf do i do??
Old Jul 30, 2005 | 03:28 AM
D87's Avatar
D87
Dang dude, if I came up to you and said, "I can't get this chair thing to work, what the hell, what do I do?", would YOU have any idea what I'm talking about???
What exactly is the problem? And when you said "everything" it would help to tell us WHAT you've tried before anyone can help, or you might have someone suggesting something you've already tried and then your agony is prolonged...
Old Jul 30, 2005 | 03:32 AM
johnboy00's Avatar
First of all, settle down.
Did you reset the HL programming by holding the two outside HL buttons for 20+ seconds until the red blinking light? Did you hold your garage door opener remote really close to the HL while programming? If your garage door opener uses rolling codes, did you then push the "Learn" button on your garage door opener (the box holding the motor), and then press the HL button you programmed 2 or 3 times within 30 secs?
Old Jul 30, 2005 | 01:52 PM
ok sorry guys lol ill calm down well heres what i did... i helpd the two outer buttons on the homelink, then i pressed the first button from the left and held it along with the garage opener it started to blink fast then i let go of both and tried opening the garage door and nothing happened.... my dad was telling me i should try it by pressing the button on the motor that opens the garage but i have no clue what hes talking about
Old Jul 30, 2005 | 01:55 PM
Inno's Avatar
1. Hold the two outer buttons, min 20 seconds, until the red blinking light flashes faster!
2. Press and hold the button on your remote control at the same time your press and hold the button on homelink till it blinks fast.
It should work...
If it is not working, you probably have a rolling code setup on your garage door opener. Then you need to follow the advanced process which uses your Learn button with your garage door opener. Read the instructions.
Old Jul 30, 2005 | 02:10 PM
xswl0931's Avatar
www.homelink.com
They have much more info than your instruction manual.
Old Jul 30, 2005 | 02:24 PM
ok so now i think theres a probelm.. well before when i would just press one of the buttons it would rapidly blink..now it just stays red so it wont even let me program it
Old Jul 30, 2005 | 02:39 PM
D87's Avatar
D87
Once again, Dad is right...
1) Get a ladder and go up to your garage door opener and unscrew the panel that protects the light bulbs in the sucker, then remove that plastic "lid"
2) You should see a button next to the lightbulbs or in the general area - this is the button everyone is talking about that you don't seem to be looking for.
3) Have someone get on that ladder and ready to push the button
4) Get back in your car with the remote garage opener and do the hold two button to erase the original code, then hold the button to want to program simultaneously with the garage door opener - you'll see the garage door close
5) As soon as the HL is set in this way, yell into the garage and ask them to press and (I think) hold the button next to the light bulbs on the garage door opener, at the same time press and hold the same HL button until it's set.
6) Test by holding the HL button
7) Enjoy!
Marlin84
Apr 1, 2020 12:52 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
vamarris
Sep 26, 2015 12:56 PM
