factory key FOB range
Old Aug 9, 2005 | 09:02 AM
rupdog326's Avatar
Out of many - one people
Anyone have any ideas on how to improve the range of the factory key fob? Anything the dealer can do?
Old Aug 9, 2005 | 09:24 AM
badtziscool's Avatar
Not really. My factory one goes far enough. Some ppl say to put the remote against the underside of your chin and that will maximize the distance. I don't know if that's true or not.
Old Aug 9, 2005 | 11:46 AM
Infinite G's Avatar
yes the chin thing works. my range is really far compared to aftermarket alarms i've had in the past. maybe you could have it looked at (if distance is a problem)
Old Aug 9, 2005 | 11:57 AM
Infinite G's Avatar
BTW how far is your range? is it bad?
Old Aug 9, 2005 | 03:08 PM
rupdog326's Avatar
Maybe @ 30 feet.
Old Aug 9, 2005 | 04:24 PM
Triple8Sol's Avatar
The range on this remote SUCKS.
Old Aug 10, 2005 | 04:52 AM
davidology's Avatar
yes, put the end with the antenna under the chin and slowly rotate it while pressing the button. I can arm it the underground parking garage from my bedroom doing that.
You can also use your wrist if you're out in a parking lot and don't want to look silly (hold it against wrist and again rotate it slowly), but I get better range using my chin.
Old Aug 10, 2005 | 11:18 AM
gspotter's Avatar
My fob will easily work from 275' away (almost the length of a football field).
I don't know why you're having trouble.
Old Aug 10, 2005 | 11:40 AM
sofl_g's Avatar
Try a fresh battery maybe?
Old Aug 11, 2005 | 10:36 PM
rcdash's Avatar
mine works at 50 feet max. under my chin the range doubles.
i will try a fresh battery...
Old Aug 11, 2005 | 10:43 PM
wezman's Avatar
whats with the whole chin thing?
Old Aug 11, 2005 | 10:45 PM
GEE35FX's Avatar
I know it helps with the chin trick, but a person sure looks stupid doing this manuevre . The first time I tried it my wife asked me how much I had to drink .
Old Aug 11, 2005 | 11:51 PM
rupdog326's Avatar
I double checked my range today and it was @50'.
Old Aug 12, 2005 | 12:15 AM
Ferrarimanic360's Avatar
hahah..yah..im wondering the same thing...
Old Aug 12, 2005 | 12:50 AM
KPierson's Avatar
The chin thing does work, but I've never found out exactly why! I have noticed though, that just raising your remote to chin level improves the distance, but not as much as acutally touching it to your chin.
When designing a remote keyless entry system engineers are constrained by limitations. They have to keep the remote small, so a small battery has to be used. And, since they don't want customers coming back for new batteries every 6 months they limit the power of the transmitter. It would be nice if it was a bit longer though, mine works at about 50', but I know of people who get less then 10' of range!
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
mbe32
Nov 13, 2015 11:09 PM
TurTLe*
Sep 29, 2015 01:43 PM
