Aftermarket Headunit and stock bose speakers question
Old Oct 10, 2005 | 07:50 PM
G Thizzle's Avatar
Question Aftermarket Headunit and stock bose speakers question
did a search and couldnt locate.
how do you bypass the Bose amp to make your stock bose speakers work with an aftermarket head unit? is the sound quality better having an aftermarket headunit hooked directly to the Bose speakers than the stock Bose system sounds?? considering doing the Kenwood DDX7017 with KNA4100 Nav. Please let me know.
Old Oct 10, 2005 | 08:18 PM
MikeyMike's Avatar
Rollin On Dubz
I changed out my blose headunit with an alpine 9813 HU. Believe me when I tell you, it's a world of difference, plus I am running a JL 12w7 and IMO you need a good aftermarket HU to run a sub. But now that I've saved up a little I am looking at replacing the components anways. But you will definitely see a huge sound difference on the stocker speakers with a new HU.
Old Oct 10, 2005 | 08:40 PM
G Thizzle's Avatar
thanks Mike... i dont plan on getting an aftermarket amp since the headunit should be more than enough power to push the stock speakers... just have to figure out how to wire the stock bose speakers to an aftermarket headunit...
Old Oct 10, 2005 | 10:29 PM
postjoe500's Avatar
Check out http://www.scosche.com/scosche/electronic/FAI3.asp. I used it and it works pretty good.
Joe
EnCr1pt3d
Jul 8, 2019 02:48 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Frostbite91
Aug 2, 2015 04:59 PM
