How do I remove the clock in an '05???
Old Oct 15, 2005 | 07:38 PM
AVJunkie's Avatar
I'm finally getting around to installing my PAC AAI-NIS. I've got everything taken apart but can't remove the clock to get to the top screw(s) that are holding the aluminum bracket that holds the HVAC and radio. The instructions that I have are from G35Ipod and are for an earlier year. The aluminum bracket will not come out as it is now so there's got to be a screw at the top holding it. Do I need to remove the clock to get to the screw? HELP!!!
Old Oct 15, 2005 | 08:04 PM
GRider35c's Avatar
its 2 pieces, pull the top piece out towards you first, then the bottom one pops up...
the top piece isnt hard to remove, but the bottom is a bitch!... gl
Old Oct 15, 2005 | 10:07 PM
AVJunkie's Avatar
Thanks, yea, I finally figured out that I needed to remove that bottom piece. It came out pretty easily with a panel removal tool.
I've got the PAC AAI-NIS working for my iPod but now my CD player won't work. I can't eject the CDs or anything!
Old Oct 16, 2005 | 06:38 AM
Gee Im Fast's Avatar
Try going to CD mode first. If your in SAT mode and trying to eject and have a PAC unit, then the PAC unit may be messing with your head unit...it may be normal, but I've never asked anyone.
Old Oct 16, 2005 | 11:59 AM
AVJunkie's Avatar
It's definitely in CD mode. Still won't work.
Old Nov 19, 2005 | 01:40 AM
MADDD_G's Avatar
was this resolved? anybody else have this issue?
Old Nov 19, 2005 | 05:59 PM
ckat's Avatar
i just ordered my pac aai-nis, will be doing an install maybe over the long weekend. i'll let you know... which instructions did you follow?
Old Nov 19, 2005 | 06:04 PM
AVJunkie's Avatar
I had to get a new HU from Infiniti to replace mine. Thankfully it was under warranty. Just make sure to remove all of your CDs before removing the HU and you'll be fine.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
