DD Install, How to ground wires?
I am in the process of doing the DD install and I am not sure how to ground the wires.
THere are a few wires that need to be grounded. Wire harness, Pac-SWI etc.
Where do I ground these wires? Are the all grounded individually? Or can you stack them all on top of each other and ground them simultaneously?
DO you need to drill a hole for each wire so you can screw them into ground?
SOme guidance would be appreciated.
