V1: Hardwire to rearview Mirror
Old Nov 1, 2005 | 10:21 AM
BocaCoupe's Avatar
G's Up, Ho's Down
Just recieved my V1 and mounted just left of my rearview mirror.
I am planning on hardwiring to the power that supplies the mirror.
I noticed therer is a plug behind the mirror I could tap into.
Does anyone know howto or has wired their detector to this power source?
Old Nov 1, 2005 | 11:20 AM
Gee Im Fast's Avatar
Edit*
Old Nov 1, 2005 | 08:32 PM
RashMan1450's Avatar
+1 Thanks Gee for my hardwire install.
Old Nov 2, 2005 | 12:21 AM
^ No worries bud.
Old Nov 2, 2005 | 12:39 AM
God|ZIlla168's Avatar
I have a question because I have the hide away or if you want the remote thingy for the v1. IS that what i need to tap inot?
Old Nov 2, 2005 | 01:32 AM
For the remote unit, I think the black is the ground and the yellow is hot. But I had to figure it out for V1 since there are no schematics in the manual, so I can't guarantee you what they do since I didnt have the remote unit with me during the install. But I am almost certain thats what it is.
Old Nov 2, 2005 | 01:23 PM
BocaCoupe's Avatar
G's Up, Ho's Down
Originally Posted by Gee Im Fast
Edit*
What happened to the information?
Old Nov 2, 2005 | 04:25 PM
Ill PM it to you in an hour or so.
Old Nov 3, 2005 | 12:47 AM
shooter's Avatar
It's not the critic......
i used the power from the mirror for a very easy install........there are 3 mirror wires, black (ground), black with red stripe (dont know), black with pink stripe (power)......just slice the cover over the mirror wires (be careful) then cut back the insulation on the 2 wires. I used the remote kit (bought it from Passport) cut the "telephone wires" to the correct length, exposed the power and ground and then soldered the wires to the mirror.....
Old Nov 3, 2005 | 09:11 PM
MISTIKMACK's Avatar
I'm interested in doing the same thing. Can this be done using the telephone wires supplied with the V1? Why did you have to use the ones with Passport out of curiosity? THanks
Old Nov 4, 2005 | 12:10 AM
my_Gthang's Avatar
thx for the D.I.Y...i ran my V1 all the way down to the drivers side cig...
Old Nov 4, 2005 | 12:31 AM
shooter's Avatar
i have a passport instead of a v1........the standard cord with the passport is the cig lighter and i didn't want to cut this up, so i purchased the remote kit instead..........
Old Dec 2, 2005 | 10:11 PM
TeamSpeed's Avatar
So is the power line switched with the ignition? Also, are there other mirror combinations for the G35, or just a couple (powered vs non-powered)? Sorry for all the noob questions, but I would like to add some of this info to my webpages for installation info for future use by customers.
Old Dec 3, 2005 | 01:15 AM
shooter's Avatar
yes, the black with pink wire is hot when the ignition is activated.....
maybe someone else can comment about other mirror configurations
Old Dec 3, 2005 | 08:01 AM
TeamSpeed's Avatar
Great, thank you! I will add these two to my installation guide for the InvisiCord.
