JL 300/4 Installed
Ok I finally cancelled the order for the JL 10w1v2 since the wait is too long... and now i have just ordered the Image Dynamics ID10 v.3 D2 from soundomain and should come by the end of this week...
im just worried about not having enough power for this sub since i have only about 150 RMS going to this sub
Originally Posted by keltoiskin
Does it matter which RCA wire you splice the positive and negative to? I would think you could potentially get out of phase. The outside RCA wire is - and the inside is + correct?
Great job on your installation! I have been thinking about doing something similar.
When you say you used the stock bolt to bolt down the MDF boards, what stock bolts are you talking about? I don't have the Bose setup, so maybe I don't have the bolts you are talking about.
I do have three threaded rods sticking up through the trunk in that area. Is that what you mean? They look pretty short to me.
Originally Posted by etang789
the amp install was not as hard as i thought. I bought some 3/4" MDF board from homedepot and cut it to the size of the amp and drill the holes for screw to go through. I have to cut 2 long strips of MDF to raise the amp in order to fit the amp into that space. I used the stock bolt to bolt down the MDF board.
Looks very nice. Any problems with heat, with the plastic cover and trunk mat installed?
Yea you found it, I used the three threaded roads that are sticking up to boat down the MDF boards. Yea they are really short, what i did was drill 4 holes on the MDF board so the threaded rods can stick through...then use a dremel kit to sand down one of the holes to fit a bolt in the middle of the MDF board.
If you do it right it should leave you one threaded rod not covered by the MDF board. I am planning to get a piece of metal bent it and reinforce the mdf board. I will get a better picture when i install the sub.
Hey finally I got the sub, but I think i got the wrong one. I wired it up and doesnt sound right? so this amp suppose to give out 75wattx4... with the 4ohm MB Quarts... and the rear bridged should it be 4 ohms or 8 ohms? now i have image dynamics ID10 v.3 dual 2 ohm subwoofer... May be i should return it and get 8 ohm which is dual 4 ohm
#30
Originally Posted by el_duderino
Bridge the R 2 channels together, wire the two vc's in Series (amp (+) to VC 1(+), VC1 (-) to VC2 (+), VC2(-) to amp (-) ) ad it will be fine.
I suspect you have the 2 VCs in parallel but out of phase with each other...
