Satellite Radio
Old Jul 24, 2003 | 11:44 AM
XtReMeLYBr0ke's Avatar
Satellite Radio
I'm considering buying a g35c in the next few months and I was wondering if i buy the satellite radio, can't I have it already installed so that when i pick the car up, i can use it? or is it just pre-wired where i have to buy the kit and do it myself? also, does anyone have a link to hidden antennas or ones that dont look fugly? does the sirius kit hook up to the factory sat. wiring? sorry for all the questions, im new here
Old Jul 24, 2003 | 04:47 PM
GforceI's Avatar
G SQUAD
Re: Satellite Radio
If I were you I would do the install myself. Infiniti will install the antenna on the roof and in my car it fits and works perfectly on the rear deck. The install takes about a half hour and is as easy as plugging in an outlet.
Old Jul 28, 2003 | 04:39 AM
Ca_Kid's Avatar
Re: Satellite Radio
I don't know what your dealer hourly rate may be, but some dealers are charging outrageous prices for the SAT install which is a real pity, because if you have ever hooked up a VCR to your TV, you can do this install. It's that easy. I posted a long message outlining how I did my install. Take a look at this picture. This is where I installed my Terk M3 antenna. Totally sealth. It is inside the rear brake light housing. My G35c did not come with the rear spoiler. I got both the SAT XM radio and Terk antenna at Scottsdale Infiniti. The Terk antenna has a lower profile than the Clarion antenna which came with my XM radio. Hope this helps.
03G35c/C_Blue/Willow/5AT/Premium/Splash/Garmin SteetPilot III/V1/SAT/XM/18" PermaStar rims w/NITTOs.
Old May 12, 2004 | 08:33 PM
nicksGUnit's Avatar
Re: Satellite Radio
Do you have the actual part number for the Terk antenna. I have been looking for one that wasn't roof mount but I can't seem to find any. I really want to get Satellite radio but I really hate the roof mount antenna. Please help!!!
Old May 13, 2004 | 12:10 AM
KPierson's Avatar
Re: Satellite Radio
If you remove all the carpet covering the bottom of the rear deck in the coupe you will find a half-dollar sized hole. If you take apart the big terk antenna that comes with the Infiniti XM box you will find that the actual antenna part is about the same diameter of the hole in the rear deck (the hole is almost in the middle and is possibly related to the third brake light that I don't have cuz I have a spoiler). If you stick the antenna part up through the hole and secure the antenna using some backstrapping you will be set. It has worked perfect in my coupe since October.
Kevin
04 Diamond Graphite Coupe - FULLY loaded
Windows up with OEM Remote
RE Short Shifter // Z Tube
Old May 13, 2004 | 11:09 AM
Anonymous's Avatar
Re: Satellite Radio
All the info you need is right here... http://www.6mt.net/shop/satradio.asp
Anonymous's Avatar
Re: Satellite Radio
Thebaws11
Jul 2, 2021 11:36 AM
G35xdriver04
Nov 7, 2015 08:31 PM
Learned Hand
Oct 1, 2015 09:02 AM
Siciliang35
Sep 18, 2015 11:22 PM
mattdg35
Sep 14, 2015 11:28 AM
