Circuit breaker or fuse?
Old Nov 3, 2005 | 09:08 AM
waijai's Avatar
i.love.gold
The system I had in my last car, the installer used a 100amp Phoenix Gold circuit breaker instead of a fuse. Is anyone else using a circuit breaker in their G's?
Old Nov 3, 2005 | 09:21 AM
amthar's Avatar
I'm using one of those standard inline fuses right at my battery. Don't know why you would want a "circuit breaker" persay.
Old Nov 3, 2005 | 09:39 AM
waijai's Avatar
i.love.gold
It's a protection device just like a fuse, except it doesn't need replacement.
100amp fuse burns out when too much current is drawn
- replace fuse
100amp circuit breaker trips when too much current is drawn
- reset circuit
Old Nov 3, 2005 | 12:03 PM
khsonic03's Avatar
I would stick with fuses. Breakers tend not to trip quick enough when it comes to sensitive electronic equipment.
Old Nov 3, 2005 | 02:19 PM
el_duderino's Avatar
Breakers also don't like underhood condsitions and most of them are too large a footprint to mount easily.
Old Nov 3, 2005 | 04:55 PM
cmayer's Avatar
circuit breaker
i have the rockford fosgate circuit breaker in my car. it is small enough to mount right by the battery, so that it is isolated away from the engine, under the battery cover. ill never have to buy another fuse.
Old Nov 3, 2005 | 04:59 PM
amthar's Avatar
Surveys say that 1 out of 1 cmayer's enjoy circuit breakers!
Old Nov 3, 2005 | 05:02 PM
BocaCoupe's Avatar
G's Up, Ho's Down
I'm a strong believer in fuses. I just have faith that when the time comes and u have a short they will pop quickly and with minimal damage. Put it this way, I have never popped a fuse in over 8 years and 3 setups. While breakers may seem nice, how often are you going to reset them. If u blow a fuse something is seriously wrong and u should re-check your install.
Old Nov 3, 2005 | 06:53 PM
Gee Im Fast's Avatar
100 Amps!!!! What the hell are you guys powering with your rides' batteries?!?!?!!!! Your house?!?!
A 100 Amp fuse will never blow lol.
Old Nov 3, 2005 | 07:23 PM
Sure it will.
200A draw for 5 seconds : )
Old Nov 4, 2005 | 12:24 AM
speedgeek's Avatar
I have a breaker by the battery and a fuse based distrubution block in the trunk. One nice thing about the breaker is the abiity to just pop the circuit when you need to do maint on the system, or bring it in for service, etc.
Old Nov 4, 2005 | 12:27 AM
Originally Posted by el_duderino
Sure it will.
Yea, then say goodbye to all your equipment during the first 2 seconds.
Old Nov 4, 2005 | 08:54 AM
waijai's Avatar
i.love.gold
How do you determine necessary fuse size? Based off what fuses the amps use?
Old Nov 4, 2005 | 10:22 AM
R2 V35's Avatar
I'm actually running a 200a circuit breaker on my G :-)
Old Nov 4, 2005 | 12:38 PM
coop's Avatar
I rock the stinger 100 amp breaker. greatest invention since sliced bread.
