newbie Sat Radio Question
Old Jul 26, 2003 | 02:33 PM
allanf714's Avatar
My G35 Coupe is not prewired but I do have a Sat button. After reading the threads for awhile I am still not clear on exactly what I need. Where can I get the harness necessary for installing the Sat Radio? Does the harness need to be installed at the dealer or can the local stereo shop do it? I understand that the hardware install is a breeze once the harness is installed, but what hardware is necessary? An antenna and receiver? I appologise for the repetition but help would be appreciated.
Thanx,
Allan
Old Jul 27, 2003 | 04:42 PM
G35MD's Avatar
Re: newbie Sat Radio Question
Pull apart your trunk to check for the harness. Take out the spare, than the black plastic covering to the left of the spare which is held by one 10mm nut/bolt. You should see the housing for your stereo amp (mine is the bose) and to the left of that is a wire bundle. If you have a white plug which is about 1.2"x0.3" secured in the middle of that wire bundle, then you have then harness. If your VIN is not too far below the published VIN cutoff for the harness, then it is prewired.
Dr. Jim
2003 DesertPlatinum G35C 6MT/Aero/Prem/Nav/HyperGround/XMSat/BSM/Tint/ClearBra/CG
2001 Acura MDX/Touring/Nav
1997 Mercedes Benx E320/Eibach Springs+Dampers/OZ Racing Superleggera Wheels
Old Jul 27, 2003 | 04:44 PM
G35MD's Avatar
I started a thread about my XM install in my prewired (but below the official VIN cuttoff) coupe.
https://g35driver.com/forums/showfla...sed&sb=5&part=
Dr. Jim
Hawk196
Sep 22, 2015 02:51 PM
Frostbite91
Aug 12, 2015 05:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Mac8008
Aug 4, 2015 09:19 PM
kd03g99
Jul 30, 2015 11:24 AM
