Does the Bose stereo problem still exist in 2006 models?
Wow, I've had at least two cars with Bose stereo's and the verdict has always been the same... crappy sound system. My first Bose car was a 95 300zx. Now 10 yrs later you'd expect they would have caught on by now, but nada. My 05 suffers from the same poor audio quality all of my other Bose equipped cars.
on
Originally Posted by amthar
I dunno about all that... considering you have the exact same speakers in your non-bose G as a bose G would have. In the end, it's still coming out the crappy speakers. The "nice" thing about the Bose system is that they EQ their output to "enhance" these crappy paper POS. I guess if you didn't like the sound, that's one thing. But as far as quality in a system, I'd still have to give the ribbon to Bose over a non-bose stock G system.
Please note that the EQ is in the Bose AMP, not the HU (Clarion). I have tested the output of the Clarion using a RTE and it is FLAT. I had already removed the Bose AMP at that point, so did not test that.
In reality the only difference between the stock and non-stock is the presence of the amp. (well and the sub for the sedan or 6x9 for the coupe, which can add unwanted boominess)
I have a JL Audio "CleanSweep" in current daily driver which is a 2003 BMW 525i but I will be removing it and I was planning on putting it on my 2005 G3c 6MT as soon as I got it. I was not sure if I should because I heard people saying it wouldnt change anything since the "EQ" was already flat and the problem is in the Bose amp......So my question is would the JL Audio "Cleen Sweep" help with the bose system?
yes only if you are adding an external amp but it is over kill. Basically it will be used for a line driver for the stock HU and it has a second input for your ipod or your whatever. If you were hoping it would EQ the Blose set up, nope!
Mark
PS I have one
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
Mark
PS I have one
Originally Posted by RichK
I posted this elsewhere, but Infinity makes both a 6.5" component and a 6.5" coax that are direct bolt ins for Bose equipped cars. The speakers even have a 2 ohm impedance so that volume level will not be affected like it is when adding 4 ohm speakers to a Bose system.
on
The EQ is in the Bose amp. If you replace it with an after market amp you will have a flat signal to work with from the HU. The Cleansweep will flatten the response of the Bose amp but only at one volume setting. As soon as you change the HU volume you've lost your flat signal. I think the Cleansweep has some gain/volume level control.
Bose is living off the rep they made 15 years ago. They are an okay consumer brand but nowhere near the high end stuff you can get.
Originally Posted by RLampke
I was unaware that infiniti made such speakers w/a 2 Ohm rating. You have some model #'s...? But even if you change the speakers, it does not remove the crap auto EQ problem, which is really the heart of the matter here.
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA50.7CS'&Ser=KAP&Cat=COS
Originally Posted by m500
Looks like the cheapest solution to get the best sound from the STOCK BOSE system will be just change out the AMP with a decent 4 channel amp. If this is the case then I don't even need to change my speaker then![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
I'm warning you, your happiness with your sound system sans stock bose amp and plus an aftermarket amp will be very low. I ran my car like this for about 2 weeks and it was the worst experience of my life. But, this is just my opinion, and apparently people with "better tuned ears" (that's one hell of an equalizer
![Wink](https://g35driver.com/forums/images/smilies/wink.gif)
