Does the Bose stereo problem still exist in 2006 models?
#31
Originally Posted by amthar
from my understanding the front and rear speakers are different ohms, which makes getting an inexpensive 4 channel amp capable of different ohms on different channels very difficult. Beyond that, you will need an amp that accepted differential-balanced inputs, or get a LOC that adapts this signal to a standard single-ended signal.
I'm warning you, your happiness with your sound system sans stock bose amp and plus an aftermarket amp will be very low. I ran my car like this for about 2 weeks and it was the worst experience of my life. But, this is just my opinion, and apparently people with "better tuned ears" (that's one hell of an equalizer ) hear otherwise.
Sorry, Now I'm a little bit confused. I believe from another post someone had actually measure the ohm of the G coupe with BOSE and confirm the voltage to speakers were 2.2 ohm stable. No to doubting you but I'm simply confused.
From your post I'm taking the only way to get some real improvement is to get a 4 channel amp that's capable of pumping out power at 2 ohm stable to either the BOSE speaker or the 2 ohm infinity speaker. Am I correct? Anyone?
#32
#34
#35
Location: Centerburg, Ohio (the geographical center of the Buckeye State)
on
hey guys,
I'm back but my G is now in the the garage while it snows here in Ohio........for those who remember, I moved from hawaii to Ohio...
I'm sooooooooooooo happy to see that there have been *significant* improvements in the quality of Nissan/Bose components since 2003.... lol
(sarcastic of course!!!)
Seriously, you would think Infiniti Customer Service would listen to its consumers and make the upgrade for the poor quality Bose or non-Bose systems......I wonder how many years Infiniti is locked into their contract with Bose......
later,
doc
later,
doc
#36
My other BOSE system car is my Wife's ML500. It had the Alpine Command system with Nav as MB OEM head unit. The clarity from these BOSE speaker is way superior then the G. No boomiest at all in the MB. Sounds like the speaker is effected by the nature/EQ of the Headunit.
Anyone BOSE equipped G replace the stock HU with aftermarket in their G with dramatic change in sound quality?
In fact many do the exact opposite with great results.
#37
#38
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA60.7CS'&Ser=KAP&Cat=COS
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA50.7CS'&Ser=KAP&Cat=COS
Anyone just replace the BOSE junk speakers - results...?
#39
on
I think the the Bose sounds fine in the G but it's definitely not worth the extra money they charge to upgrade from the base system. The only reason I got it was because it was included in the premium package. Actually I only wanted the homelink mirror and that was the only way to get it at the time.
If you want it to sound better, get the PAC AOEM-NIS2, and plug in your own EQ & Amp and you can customize the sound to your liking. I got the PAC AOEM-NIS2 for my subs. This thing plugs straight into the back of the bose head unit & has front & rear outputs w/ gain control & remote line for the amp. Much better than splicing into the speaker wires with other line out converters. Sells for less than $50 on ebay. I would probably change the speakers out too because the Bose speakers are designed for "bose" music (i.e. acoustic, classical, soft, etc.). Not rock, rap, or techno.
#40
do any of you who have an 06 have the same equalizer glitch that if im not mistaken 05's have, its when you change all settings to + 5 and then if you turn off the car or leave the stereo off for a long time and then turn it on again everything resets....ive been wondering this for a loooooooong time
#42
Originally Posted by AVJunkie
He's not getting nasty, just stating fact. All Bose systems suck. There's nothing wrong with the G35 Bose system that isn't also wrong in every other Bose audio system.
#44
Originally Posted by el_duderino
What issue, that all Bose systems suck? In the last two days at my shop I've gotten calls from former Lexus owners who bought Mercedes with Bose, and wanted to upgrade their stereo to be as good as the Lexus.
Would you classify this as a launch problem, or a design problem?
Val Kilmer, Real Genius
