Single-din head units
Old Nov 22, 2005 | 01:12 PM
KFM's Avatar
KFM
I have an 06 G35x, and Im looking to install an aftermarket head unit. Can a single din head unit be installed, and, if so, does anyone have any pictures of this?
I searched and did not find an answer.
Thanks.
Old Nov 22, 2005 | 01:46 PM
showtime240's Avatar
For a clean install you will still have to buy the DD kit....
You can put the single din HU and have a pocket below....
Old Nov 22, 2005 | 01:54 PM
MikeyMike's Avatar
Rollin On Dubz
You need a double din head unit. Run a search on that. It's possible, but that price can be a little pricey.
Old Nov 23, 2005 | 04:36 PM
postjoe500's Avatar
I did a single din upgrade a few months ago to a 05 G35x.
Two issues. You need the JDM bracket, even though the 05 has a bracket. The holes on the JDM bracket are farther forward, so when you install the pocket everything is flush. If you use the stock bracket, there is a slight gap between the pocket and the trim.
The other issue I experienced was another slight gap between the bottom of the stereo (Kenwood) and the pocket. I ended up making a piece of plastic trim to hide the gap.
I've attached a picture with the final result.
Old Nov 26, 2005 | 08:01 PM
Back2VQ's Avatar
will i need a new AC control unit for a single din install with the JDM bracket? looks like in the picture DUAL button is missing. i have the DUAL a/c in my car, could i just use the A/C control unit i have?
Old Nov 29, 2005 | 10:13 PM
postjoe500's Avatar
Yes, you still need all the DDIN components (AC unit, Trim, etc).
The DUAL button is missing because I didn't bother with the soldering. The JDM AC unit has the functionality, but not the switch soldered to the circuit board.
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
