Best 2-way alarm?
Old Nov 30, 2005 | 01:18 PM
  #31
Pearl05G's Avatar
Originally Posted by khsonic03
Pearl05G: Where is your antenna mounted?
Passenger side windshield.
Old Nov 30, 2005 | 01:19 PM
  #32
Pearl05G's Avatar
Originally Posted by streetdriven
791 does not have onboard relay for the trunk pop, so please tell me how u hooked it up.
Its a negative out, so direct connect. Unlike older Maximas which needed chassis ground via relay to pop.
Old Nov 30, 2005 | 02:24 PM
  #33
el_duderino's Avatar
What he means is, it's a LOW-CURRENT negative out from the switch popping a relay in the car. Already has a relay, doesn't need another one.
Most have 12V going to one side of the solenoid and the other side gets a chassis ground from the switch, and when you press the button it passes more current than the poor (-) out transistor on the alarm can handle. Thus, the relay, which is just a spring-loaded mechanical knife switch with a low-current electric motor tied to it. (Think of it as hving a leprechaun inside who throws the switch whenthe light goes on...)
Old Nov 30, 2005 | 05:23 PM
  #34
Pearl05G's Avatar
Thank you sir for the explaination. I was vague in description assuming he knew what I meant.
g.spot
May 9, 2016 10:54 PM
JMSABO
Aug 4, 2015 11:58 AM
gabe3d
Audio/Video/Electronics
Jul 19, 2015 05:43 PM
flex7825
Apr 9, 2004 11:30 AM
