Hey RichK - Infintiy Kappas
Seems like I remember you were going to do an install of some Kappas into the OEM locations since they ran a 2 ohm version that would work with the stock Blose HU....
Still waiting for you opinions on the install and resulting sound improvement...
Here you go. 2nd post down.
https://g35driver.com/forums/showthr...t=75337&page=3
I just installed them in my G35 coupe as well. I've also added a 4080 sub box loaded with a JL Audio 10W1V2 and Alpine MRV-F450 5ch amp. The Infinity Kappa'a have amazing clarity and made a huge improvement over the stock speakers.
Yeah. I made 1" mdf spacers and spray painted them black to mount the speakers to the door. I traced the outline of the stock bose speakers to make the spacers. I mounted the tweeters in place of the stock ones with 3m double sided foam tape. I mounted the crossovers to the doors on a flat spot above the woofer. Do a search for speaker install and tons of info will come up for you to read.
Here's a link to instructions for the door panel removal:
http://digitalwheelz.com/diy/doorPan...val/index.html
