iPod and Sirius Satellite
Old Jan 21, 2006 | 11:17 AM
pevans1027's Avatar
So I have had my new 2005 G35 Coupe for 1.5 weeks now and I need to do two things: Hook up my iPod and get the Sirius satellite radio in the factory unit. Here is what I've encountered so far.
iPod - I purchased the Griffin iTrip and it kind of sucks, too much static and I would really like to get this hard wired in, but am weary about getting the perfect aftermarket solution.
Sirius - The dealer wanted $600 dollars to install it in the factory unit!!. I know they like to overcharge, but I thought this was a bit ridiculous and thought I would shop around. Can I purchase the factory kit myself and install it? I am using a Sirius Starmate right now and have it hidden where the Navi goes and its ok, but would rather have it in the factory unit.
Is there an aftermarket deck that would fit into this car without modifying the whole dashboard? Looking for some ideas. Hope you all can give me some advice.
Thanks....
Old Jan 21, 2006 | 11:24 AM
BlackonBlackG35's Avatar
You can buy the reciever here much cheaper: http://www.grubbsperformance.com/Mer...=G35CoupeAudio
Most likely you can install it yourself. Check the audio section for more info.
Old Jan 21, 2006 | 01:18 PM
absolutg's Avatar
workin...
PAC AAI-NIS2 from Pacific Audio. You can pick it up from logjamelectronics.com (it's on backorder as AAI-NIS but should be available soon)
provides an AUX in for your ipod connection and also allows the sat connection to work
I'm getting mine in a couple of weeks hopefully!
Old Jan 22, 2006 | 10:10 AM
luv2drive's Avatar
20 Year Member
IPOD FM transmitters typically don't give very good sound. That said, the ipodlounge.com did a review on FM Transmitter products. Based on that I bought this one:
Kensington Digital FM Transmitter for iPod - It is made by company Aerielle for the company Kensington and you can buy in stores or many Web pages such as - http://www.aerielle.com/shop/index.html. It looks like they build for Iriver U10 model and also many others.
It charges, powers and does FM transmission all at once and the sound it just like the review said... awesome. I am very happy with this product.
Hope this helps.
Old Jan 22, 2006 | 10:17 PM
pevans1027's Avatar
Thanks...I will check it out.
Does anyone know if the factory deck has an auxiliary plug in the back to attach an RCA adapter cable, I have seen them in Crutchfield, but I can't tell if it is for a G35 or not.
Thanks.
Old Jan 25, 2006 | 04:37 PM
pevans1027's Avatar
I bought that FM Trans you suggested and it is awesome..thanks.
Old Jan 25, 2006 | 04:51 PM
Mike_Deezy's Avatar
I just installed my Sirius SAT last week and I am going to need this for my iPod as well. How easy/hard is it to hook this up? I'm clueless when it comes to these kinds of electronics.
Old Jan 30, 2006 | 03:49 PM
Clay's Avatar
the PAC AAI-NIS2 says it only works for 2003-2005 Infinitis - is that because it simply hasn't had it's description updated, or did something chance?
Does the 2006 G35c come with the auxillary input?
Old Jan 30, 2006 | 05:19 PM
absolutg's Avatar
workin...
they haven't updated the description. it works for the '06 and i've read people having them installed/installing them themselves with the '06. i'm getting my unit on wednesday so by sunday i should have a post up with pics/results
Old Jan 31, 2006 | 03:38 PM
Clay's Avatar
I would actually love to see how it integrates with the system. Anybody have any pictures they could put up?
Old Feb 1, 2006 | 10:36 AM
Noremac's Avatar
The Pacific Audio AAI NISV2 description says:
"Will NOT work if the vehicle is already equipped with a satellite receiver."
So what is the right answer? Will it work with factory Sat, or not?
Old Feb 1, 2006 | 12:33 PM
SI_G35Coupe's Avatar
that's because the description they have on that website is the write up for the AAI-NIS, not the NIS2. only the top part of the text applies to the NIS2.
http://www.pac-audio.com/instructions/AAI-NIS2.pdf
if you open up that PDF, which is PAC's installation instructions, it has a section clearly marked "For Vehicles with SAT radio installed". the NIS2 adapter has a switch that you can set for either "no sat" or "with sat". if you install it with SAT radio... presents 1-2 control the AUX inputs, and presets 3-6 operate as normal sat radio presets, if i'm reading their instructions correctly
Old Feb 1, 2006 | 03:26 PM
Noremac's Avatar
Originally Posted by SI_G35Coupe
presets 1-2 control the AUX inputs, and presets 3-6 operate as normal sat radio presets, if i'm reading their instructions correctly
Any idea about the other 6 presets (SAT2)? Do you still have use of all of them for satellite channels?
Old Feb 2, 2006 | 11:51 AM
luv2drive's Avatar
20 Year Member
Glad I could help Pevans1027. I agree that the Kensington FM Transmitter for IPOD is the best on market! I love mine.
For all others that are looking for a good FM transmitters for IPOD / Iriver / or just any MP3 player...try these guys. I am not trying to promote their products... they just have the best sounding FM transmitters on market and I wanted to share with forum.
You can see their products at www.aerielle.com
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
mattdg35
Sep 14, 2015 11:28 AM
wuppiedog
Aug 7, 2015 11:16 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
