My Stereo Upgrade
Old Aug 14, 2003 | 09:59 AM
paintballbitch's Avatar
My Stereo Upgrade
I have finally finished my stereo upgrade...
Check it out at
http://www.imagestation.com/album/?id=4289402339
I went the cheap route with a plexi glass on top....
Old Aug 14, 2003 | 10:22 AM
justme97's Avatar
Re: My Stereo Upgrade
Awsome looking! Could you give us a summary of what you did?
Old Aug 14, 2003 | 11:08 AM
Front: Soundstream Exact 6.3 Component
Rear Side: Soundstream SST 6.5
Powered by Soundstream Rubicon RUB600-4
Sub Box: Kicker Solo-Baric S8L7 Loaded Box
Powered by Kicker KX800.2
Lightning Audio 1 Farad Cap
Old Aug 14, 2003 | 11:25 AM
justme97's Avatar
Stock bose head unit? Did you feed the pre-amp stock HU feeds directly into your amp or use some sort of converter? Do you think keeping the stock HU handicaps the sound or are you happy with the range now that you have a better amp/speakers?
I can't wait to get started on mine!
Old Aug 14, 2003 | 11:59 AM
I am getting my friend to look into the JDM Double Din Console... and then I can get an aftermarket HU in there
I used Line Out Convertors, the sound is definitely better than the stock but not as good as I imagine... I am going back today to tune the system
Old Aug 14, 2003 | 01:29 PM
limeg35's Avatar
ahhhhh.....sweet pic of the rubicon, very NICE...need to change out the stock bose to get full SQ out of speakers...have you noticed that, when you drive at higher speed(40 and up) it sounded better? i think is that SVC thinging, maybe stock H.U. give more volts at higher speed?...s.w.
03 coupe 5AT DG/G premium,performance
Old Aug 14, 2003 | 01:52 PM
malx's Avatar
Are you sure about that limeg35? I don't think that is true, might be, but I doubt it.
Thanks - Joey Avino
Old Aug 15, 2003 | 10:12 PM
04NismoV35's Avatar
What kinda of line out converters did you use? High/Low? I posted a reply to sub/amp question, you may wanna look at if. I f you use the items I listed and add an Audio Control Four.1 parametric EQ w/ voltage booster you should be able to stay stock and get the performance your looking for.
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
NailBomb
Oct 28, 2015 07:53 AM
NyCrAzY
Oct 1, 2015 09:19 AM
