Anyone Install Two Pairs of 6.5's Up Front In A Coupe?
caskyline that's awesome!
what i'm trying to fit into the doors are a set of CDT eurosport 6.5's and a set of RE XXX 6.5" midbass speakers.
what kind of depth did you have behind the 4"?
in terms of depth is there enough for a real 6.5" driver where you've located your 4"?
looks like width / circumference wise i may have to move the stock 6.5" forward though.
To get two 6.5" in the door you will definatly need to do custom work to the door panel.There is room in the door,no problem.With the set up I did it makes a great 3 way set up,exellent sound quality.It was a very close fit for the 4". Basicly all I had to do was cut the door panel and run new speaker wire.
