My Install Thread
Old Jan 30, 2006 | 08:16 PM
jeremyp111's Avatar
Originally Posted by Virge
does the audio for navigation plug into non-oem hu's? or is it some kind of proprietary connection for the stock hu only?
No. Stock HU only. However, you can connect a powered speaker to the output of the navigation to hear the Nav audio when using an aftermarket HU. Do a search. It's been discussed before.
Old Jan 31, 2006 | 11:46 PM
SleekStyle's Avatar
where did u get that box? custom?
Old Feb 1, 2006 | 06:37 AM
jeremyp111's Avatar
That box is made by 4080. Do a search for 4080 subwoofer box. You'll find it. He sells them for around $300. I have one as well.
Old Mar 2, 2006 | 08:17 PM
Real_G's Avatar
An Army of One...
On the 4080.. where is the metal bracket at the top of the box? Does it go inside the trunk? I have seen it out and Ive seen some with out it exposed.
Old Mar 3, 2006 | 04:22 AM
jeremyp111's Avatar
The metal bracket goes under the weather stripping. You need to lift up the weather stripping, press the box in place so the metal bracket is flush with the trunk lip and push the weather stripping back down over the lip/bracket to hold it in place.
Old Mar 3, 2006 | 04:38 AM
etang789's Avatar
hey bluerex how did u ground the amps? I need some hint for my upgrade install
Jusseth
Sep 13, 2020 12:25 PM
Xfactor
Dec 1, 2019 12:52 PM
RA081024
Aug 18, 2015 07:03 AM
saskicker32
Aug 11, 2015 02:12 PM
yassy
Aug 9, 2015 07:31 PM
