Why havent i seen any coupes with a Kenwood DDX Double Din Installed??
Old Feb 1, 2006 | 04:12 PM
OZSponsoredjti's Avatar
Such a nice head unit, why dont any of you choose that??
Old Feb 1, 2006 | 04:23 PM
GXCLUSIV's Avatar
Just to name a couple " G352NV " and " Paranormal " have Kenwood DD unit.
Old Feb 1, 2006 | 07:22 PM
TheDoG35's Avatar
I just put one in (a 7017), I'll post a picture of it before too long. So far, all good. I need to live with it for a while before passing judgement. Went in along with a Sirius tuner, the iPod interface, and a PAC SWI-ALP unit (wired) for the steering wheel control replacement.
My only complaint - I'm not sure I'm happy at all with the trim ring. I'll make the one that came with the unit work, but if anyone has a better solution, pass it along!
Old Feb 4, 2006 | 02:42 PM
paranormal's Avatar
yeah i have the ddx 8017
Old Feb 4, 2006 | 07:41 PM
wanalaugh74's Avatar
yo jimmy,
can i pick your brain about your HU?
8017 the newer model to the 7017?
Did you get the NAV also?
Is it easy to tbypass the DVD playback/NAV controls?
Old Feb 4, 2006 | 08:05 PM
paranormal's Avatar
i didnt get nav also. i already have nav in my car.. and if your refering to watching dvd's while watching than yeah its easy.. mine works fine.. love it.. and the eq controls are insain
Old Feb 5, 2006 | 12:33 AM
shellbmb's Avatar
Ddx6019
Just FYI. KW is coming out with a DDX6019 in March/April that will be a DDin unit. It will be compatible with their new 2006 bluetooth adapter; however, I believe it will not be an excelon unit so sonically it might be a little weaker than the 7017 and 8017. That makes no sense to me, but whatever. This all comes from the KW contact person I found on their CES webpage.
Old Feb 5, 2006 | 02:04 PM
SFLG35's Avatar
FGC President
ask and you shall recieve
Attached Thumbnails Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-kenwood-ddx-7015-install001s.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-kenwood-ddx-7015-install002s.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-kenwood-ddx-7015-install003s.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-kenwood-ddx-7015-install004s.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-kenwood-ddx-7015-install005s.jpg
Old Feb 5, 2006 | 02:06 PM
SFLG35's Avatar
FGC President
here is the link to my install thread
https://g35driver.com/forums/florida-g-club/83587-my-install.html
Attached Thumbnails Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-kenwood-ddx-7015-install006s.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-kenwood-ddx-7015-install007s.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-kenwood-ddx-7015-install009s.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-kenwood-ddx-7015-install011s.jpg
Old Feb 5, 2006 | 02:10 PM
SFLG35's Avatar
FGC President
last friday two days ago
i put in the kenwood sirius tuner and mounted the antenna on the front dash in the passengers side corner. i have 5% tint on the sides and rear so that wouldnt work too well. i have 30% on the windshield and it seems to be able to pick up threw that.
i also installed a ps2 slim in the lower glove box. had to drill out the back though a little bit to be able to close the glove box with the ps2 still connected
Old Feb 5, 2006 | 03:49 PM
SFLG35's Avatar
FGC President
sirius
Attached Thumbnails Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-sirius-ps2-install-002.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-sirius-ps2-install-003.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-sirius-ps2-install-004.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-sirius-ps2-install-008.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-sirius-ps2-install-009.jpg
Old Feb 5, 2006 | 03:51 PM
SFLG35's Avatar
FGC President
ps2
the last pic shows the big hole i had to drill for the connector to go threw. i didnt have a dremel so i had to use a 1/2inch drill bit. im goin to borrow my buddies dremel and fix but hte hole and make more of like a rectangle so it will look alittle better
Attached Thumbnails Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-sirius-ps2-install-005.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-sirius-ps2-install-006.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-sirius-ps2-install-007.jpg
Old Apr 23, 2006 | 03:17 AM
G35Dubs's Avatar
hey guys, im finishing up my kenwood 7017 double din install tommorow. I got the new bezel together, and the deck mounted in the stock bracket. I tried putting on the trim ring and it wouldnt fit so i trimmed the inside edges. But it still sticks out on top of the double din finisher a lot and the kenwood deck sits recessed inside quite a bit. I dont like how it looks at all.
What did you guys do to make your trim rings fit on the kenwood deck?
Also, did you modify the stock cage at all? It seems like using the stock holes makes the deck sit too far back.
Old Apr 23, 2006 | 06:01 AM
imalazeeass's Avatar
Old Apr 23, 2006 | 04:58 PM
G352NV's Avatar
Never enough
I fiberglassed my trim ring, its custom.
Attached Thumbnails Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-picture-1811.jpg   Why havent i seen any coupes with a Kenwood DDX Double Din Installed??-picture-2007.jpg
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
EnCr1pt3d
Jul 8, 2019 02:48 PM
kd03g99
Jul 30, 2015 11:24 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
