Which 10W3v2 with 4080 Box?
Old Feb 6, 2006 | 04:12 PM
e420x's Avatar
Mod Junky!
I am going to get a 4080 box and am wondering which Jl Audio 10W3v2 is the one to get
<table align="center" border="1" cellpadding="6" cellspacing="0" width="100%"> <tbody><tr align="center" bgcolor="#2d4472" valign="top"><td>10W3v2-D2</td> <td>10W3v2-D4 </td> <td>10W3v2-D6</td></tr></tbody> </table>
Old Feb 6, 2006 | 04:28 PM
GXCLUSIV's Avatar
10w3v2 d4, dual 4-ohm. You can also get the 10w6v2 d4, it can handle more watts.
Old Feb 6, 2006 | 04:29 PM
e420x's Avatar
Mod Junky!
I plan to run the JL 250/1 . I do not plan to upgrade the stock speakers and amp so I figured the W6 would be overkill
Old Feb 6, 2006 | 04:31 PM
GXCLUSIV's Avatar
That is a great combo, JL 250/1 with 10w3v2 d4.
Old Feb 6, 2006 | 06:46 PM
jeremyp111's Avatar
If you are running a 250/1 then you can run a 10W3V2 D2 or 10W3V2 D4. If you run the D2 then make sure that you wire the voice coils in series for a 4 ohm load. If you run the D4 then make sure that you wire the voice coils in parallel for a 2 ohm load. Either will be fine since the 250/1 can run at 1.5-4 ohms.
suby01
Not G35 Related
May 25, 2016 03:07 PM
prinny
Nov 22, 2015 11:07 PM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
Learned Hand
Oct 1, 2015 09:02 AM
