Secret cavities in the G35? :)
Old Feb 13, 2006 | 05:04 PM
amthar's Avatar
Anyone know of a spot in the front of the car (forward of the front seats, preferably in the dash somewhere) that has room for a device measuring:
4.6" x 3.25" x 1.75"
Any suggestions? Can't be anywhere that will get wet.
amthar's Avatar
ROFL. I just re-read that and realized how bad it sounds. No, I'm not transporting drugs. It's for a power supply for my car PC that is going in my glovebox. I really don't want to run power wires all the way from the trunk to the dash.
Bad bad people for thinking that!
Old Feb 13, 2006 | 05:17 PM
caelric's Avatar
280ZX is the car of choice for drug runners. Secret cavities al around the back/trunk area...
On a serious note, have you lifted up the carpet on the passenger side? You might find some space there, or kind of up where the ECU is.
Dave
Old Feb 13, 2006 | 05:32 PM
WhosUrBuddiee's Avatar
there is that secret compartment between the two back seats
Old Feb 13, 2006 | 06:17 PM
g35rcr's Avatar
behind the console where the ashtray is located has a space thats bigger then what you need...just take off the cover on the shift **** to access it
Old Feb 13, 2006 | 07:03 PM
limeg35's Avatar
Right under the steering wheel, other side of the plastic cover, where the most of alarm brain goes
Old Feb 13, 2006 | 07:06 PM
badtziscool's Avatar
I know a girl with a couple of cavities the size that you're looking for. Will that help?
Old Feb 13, 2006 | 08:23 PM
afr0puff's Avatar
Supa Dupa Moderator
There is a spot as big as the fuse panel on the passenger side. Just pop that panel/trim piece out. Let me know how the glove box install goes. I'm thinking of doing the same.
Old Feb 13, 2006 | 09:22 PM
amthar's Avatar
Already being used as a hard drive storage rack
I think this wins it as it is right below the screen location (allowing for each wiring to it) and not too far from the upper glove box. AND I remember seeing a lot of room when I was doing the PAC-AAI-NIS2. That's choice #1. Thanks guys, this is all very helpful!
- Josh
Old Feb 13, 2006 | 10:13 PM
mikedaddy98's Avatar
I'm wondering how "wide spread" his carputer is gonna be....
Old Feb 14, 2006 | 03:26 AM
gizsf's Avatar
You'll be pretty suprised when you pull out the seat and see whats under the carpet! I was actually planning to build a carputer case to fit there.
There is also a little bit of space behind the glove box, but heat build-up would be an issue. Under the center console there is also a bit of space too.
Old Feb 14, 2006 | 08:47 AM
amthar's Avatar
Huh?
Old Feb 14, 2006 | 08:48 AM
amthar's Avatar
Can you explain a bit more?
And if you were going to worry about heat dissipation behind the glovebox, wouldn't you worry about it under the seat / under the carpet?
Old Feb 14, 2006 | 02:45 PM
SI_G35Coupe's Avatar
look behind the passenger "kick panel" (the plastic panel just forward of the passenger door... i fit my AV Electronic unit in there and there was room to spare
Old Feb 14, 2006 | 03:21 PM
Destro's Avatar
But he needs a place that won't get wet.
