Spent 3 hrs wiring spkr wire to door, now a problem with the window roll up!
Old Mar 3, 2006 | 03:23 AM
htn's Avatar
htn
10awg no problem???? how did you do that??? I just spent 5 hours running 12awg to both doors, and it's a pain,,,,,,,,but i didn't take the doors off though
Originally Posted by Pearl05G
I wasnt worried about taking it off, just didnt want to take the time.
I ran 10awg and 14awg with no problems. In fact theres an additonal pair of 18awg wires for my alarm.
Old Mar 3, 2006 | 03:25 AM
htn's Avatar
htn
I've just spents hours running wires thru the door and was thinking what's the point??? the wires that are connected to the tweeters are small as heck,,,so what does better wiires do if the wires that are so small that the tweetes come with,,,,
Originally Posted by caelric
You don't *have* to run new wire. However, if you are running much higher power than stock, it is recommended.
Also, since I am bi-amping my fronts, it's required to run new wire. Bi-amping is using a four channel amp (in this case, the JL 450/4) to power a single set of components (2 woofers and 2 tweeters) It generally can improve the osund quality quite a bit (or so I'm told..).
So, new speaker wire.
By the way, taking the door off wasn't that difficult, I'm a relatively big guy, and I can hold the door up myself. 4 bolts, and it is off...
Dave
Old Mar 3, 2006 | 09:10 AM
amthar's Avatar
chirp chirp tweetes tweetes
Old Mar 3, 2006 | 09:55 AM
caelric's Avatar
There are no seperate wires running from the bose amp to the tweeters. So, like I said, if you are bi-amping, you need to run newwire.
Dave
Old Mar 4, 2006 | 01:30 AM
caelric's Avatar
Well, apparently I learned something, because it only took about 1 hour to run wire to the passenger door, and it was much easier to do so. I figure if I had to do it again, it would take even less time.
Now to finish off the rest of my install on Saturday.
Dave
Old Mar 4, 2006 | 07:11 PM
maaloxx's Avatar
HAve you checked all your fuses!
Old Mar 4, 2006 | 08:09 PM
caelric's Avatar
Did you read the rest of the thread, whre I mentioned that I had fixed the problem?
Dave
chinee
Jun 10, 2024 07:48 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
