OEM Disc Player Stuck!!!!!
Old Mar 9, 2006 | 09:53 PM
kevinr3d's Avatar
HAs this happened to anyone else? Are there any suggestions aside from replacing the head unit? It reads disk check and doesn't appear to shuffle fully through the disc and then stops. It then reads Disc Error FO. I can not eject any disc or do anything with the disc player any advice is helpful. I attempted to disconnect the battery to reset the player but that didn't work either...
Old Mar 9, 2006 | 10:59 PM
absolutg's Avatar
workin...
other ppl have encountered this. i think ur HU is fubar... the dealer might be able to get your discs out but they should replace this under warranty. otherwise, maybe go double DIN/new HU...
Old Mar 9, 2006 | 11:14 PM
GEE35FX's Avatar
Same thing happened to me on my 05. The dealer replaced the HU. It took over 4 months to get my 6 cds back from the old unit .
Old Mar 9, 2006 | 11:44 PM
bfan13's Avatar
mine got stuck about 2 months ago. I had to bring it to the dealer and show them so they would order the HU, then i had to bring it in again to get the HU replaced, then they mailed back the cd's a few weeks later
Old Mar 10, 2006 | 02:42 PM
g6g35's Avatar
just go to the dealer and get it replaced, it's under warranty. It took my dealer a couple of weeks to also get the cd's back to me in the mail.
Old Mar 10, 2006 | 08:08 PM
accordfreak's Avatar
haha they probably burned a copy for themselves then returned it back to you guys..
I have the 05 on my 04. It got stuck so I had to take it apart to realign the tracks. It works fine now.
Old Mar 13, 2006 | 11:12 PM
ushmond's Avatar
you said that you fixed it yourself, i've got an '03 and 6 disc stuck, i don't know if i'm still covered under warranty, i'm at 70,000 miles. just wondering, should I try to fix it on my own? (following details on taking apart console in other posts) or just suck it up and bring it in?
Also, was it hard for you to do it yourself? any details on how you got the cd's out? Thanks.
This disc jam sux.
Old Mar 14, 2006 | 12:26 AM
follow the instructions on how to take out the radio.
After that, take out these screws pictured below.
plug in your radio with it exposed and see what is stuck when it is moving.
the rods that hold up the trays could be off track.
OR turn it upside down, and plug it in. While it's trying to cycle through the cd trays, tap the unit with a fair amount of force. Sometimes that does the trick.
Attached Thumbnails OEM Disc Player Stuck!!!!!-img_5147.jpg   OEM Disc Player Stuck!!!!!-img_5146.jpg
Old Jul 3, 2007 | 11:37 AM
jist26's Avatar
stuck cds in 6 disc indash
thanks gonna try that this weekend, did you have to reset the car to clear the message or did it go away on its own?
Old Jul 3, 2007 | 04:33 PM
Deezflip's Avatar
Once the CD's are removed? Will the CD ERROR FO go away? Will i be able to use the CD player again? I sure hope so, i was meaning to take the radio apart when i found some free time.
Old Jul 3, 2007 | 04:38 PM
darnelled's Avatar
Press and HOLD the eject button even when it starts beeping. Mine ejected the discs finally and has worked fine ever since.
I made a 4 hour roundtrip to the dealer just to have them say they do not work on the HU -the whole thing gets swapped out. It is a fast swap but they have to order the part. I called back to cancel the order and appt. after I fixed it.
Old Jul 6, 2007 | 09:39 AM
jist26's Avatar
tried the hold eject method all i get are the beeps and the error msg,
but the other day it decided it wanted to spit up 2out of 6 of my cds.
Old Jul 12, 2007 | 02:04 AM
JoeMac's Avatar
Any idea if they'll have a problem with the PA11-NIS being installed? Think they'll hook it back up? I sure hope so. My CD player has been fubar for a couple months now. Going to try and take it in on Friday.
Old Jul 17, 2007 | 04:00 PM
mediabox's Avatar
mine too got jammed. unit replaced, cd's followed a few weeks after.
Old Jul 19, 2007 | 01:34 AM
octupus23's Avatar
I just got the F0 error about 3 days ago :S.... $600 in the dealer to have them replace it for a refurbished unit.... don't know what to do yet, might try opening the radio somebody said in this thread.... does anybody have the link handy to how to take out the radio... 03 sedan.... thanks...
