Radio Removal/PAC install help needed
Old Mar 10, 2006 | 12:35 PM
STill_matic's Avatar
Arrow Radio Removal/PAC install help needed
I'm going to install my PAC AAI-NIS2 tomorrow, but I can't find a do it yourself anywhere.
Can someone post a like to a DIY for the radio removal, and anything else that might help.
Thanks in advace
-dan
Old Mar 10, 2006 | 12:43 PM
maaloxx's Avatar
links
I asked the same question...the links to the info you need are here in my original thread:
https://g35driver.com/forums/audio-video-electronics/89002-bose-hu-removal-diy.html
Old Mar 10, 2006 | 12:58 PM
https://g35driver.com/forums/showthread.php?t=89002
Thanks. This AAI-NIS2 install is going to be a ******* b!tch.
Old Mar 10, 2006 | 01:20 PM
absolutg's Avatar
workin...
i've been lazy, i'll post pics from my install tonight in my thread and link it here. 16psibrick helped me out with wiring the Blitzsafe unit, not sure if you got that for powering an ipod...
Old Mar 10, 2006 | 01:22 PM
Mike_Deezy's Avatar
Is the install really that difficult or is it just time consuming?
Old Mar 10, 2006 | 01:48 PM
absolutg's Avatar
workin...
05 and newer, it's not too bad. 04 and older, takes a lot longer.
for now, check out http://g35ipod.com
Old Mar 10, 2006 | 01:50 PM
maaloxx's Avatar
Why didn't you get the USA spec unit from crutchfield? It's plug and play! and it powers the IPOD and you maintain your steering wheel controls.
Old Mar 10, 2006 | 01:54 PM
spmc's Avatar
Not that difficult, just time consuming, if you are trying to be careful. About 2-3 hours.
Hardest parts are;
1. Removing the trim piece by the clock.
2. Removing and swapping the plugs on the back of the radio.
Everything else is just removing screws and pulling off parts.
Remember to tape all your dash off with blue painter's tape before you start or things will get scratched.
Old Mar 10, 2006 | 02:26 PM
nm3th's Avatar
I installed mine in about an hour. But then again, I have an 06 so the console removal was a breeze.
Old Mar 10, 2006 | 02:29 PM
Mike_Deezy's Avatar
I didn't know that. Reason why I held off on purchasing one was b/c I heard that there wasn't a unit that works with our steering wheel. Will this work for me if I have SAT? Where can I buy one?
Old Mar 10, 2006 | 04:14 PM
jcn83's Avatar
DIY BOSE HU REMOVAL FOR 06? Instructions? Any help?
Considering the PA11-NIS from USASPEC and wonderining what the install is like....THANKS
Old Mar 10, 2006 | 04:56 PM
maaloxx's Avatar
If you got a SAT button your set! plugs right into the sat plug and the factory plug plugs right in so you get to keep all your steering wheel controls. i got mine from crutchfield.com
Old Mar 10, 2006 | 05:05 PM
I’m just using it for 2 aux audio inputs.
Old Mar 10, 2006 | 05:49 PM
Mike_Deezy's Avatar
I have my SAT tuner plugged in right now, is there a way to plug them both in?
Old Mar 10, 2006 | 06:10 PM
amthar's Avatar
PAC-AAI-NIS2 lets you keep your stock sat tuner and still add ONE aux input channel
