Can your car do this? Official Teaser
Old Dec 27, 2006 | 11:05 PM
  #106
KPierson's Avatar
No, the OEM switch isn't just a simple switch, it's overly complicated and at rest nothing is connected inside the switch.
Old Dec 28, 2006 | 07:09 PM
  #107
afr0puff's Avatar
Supa Dupa Moderator
For those that get the one with two modules, is it possible to have that one contain the "center/off" switch? So that we don't have have to go into reverse, then pop it out and back in?
Old Dec 28, 2006 | 08:12 PM
  #108
KPierson's Avatar
Most likely not because then you wouldn't be able to do both at once, if you should want to.
Old Dec 31, 2006 | 11:31 AM
  #109
afr0puff's Avatar
Supa Dupa Moderator
So what happens if you are parallel parking, and you need to "fix" a bad entry? You may end up switching between R and 1st about 4 times. How will the mirror behave in that scenario?
Old Dec 31, 2006 | 02:31 PM
  #110
QuadCam's Avatar
Hey Kevin,
Did you ever get your fuel pressure issue solved?
Andrew
Old Dec 31, 2006 | 02:53 PM
  #111
KPierson's Avatar
Once you either engage it (2 reverse pulses) or bypass the system (1 reverse pulse) the system waits until the car has been out of reverse for ~10seconds before it will look for commands again. This should allow most people to parallel park without the mirror moving at all.
Old Dec 31, 2006 | 02:54 PM
  #112
KPierson's Avatar
Originally Posted by QuadCam
Hey Kevin,
Andrew
I got your message, sorry I didn't get back with you. I still haven't done anything about it. I have a new fuel pressure regulator sitting in the car, but the shop that does my work has been too busy to fit me in. I'm hoping that it's the regulator and not the pump, as it was in your case.
Old Jan 2, 2007 | 04:01 PM
  #113
Igor911's Avatar
I'd be interested in one of these modules.
Subscribing...
Old Jan 2, 2007 | 08:11 PM
  #114
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
Wow! Awesome work and something I have long waited for. This is a much need addition to this car... and many others.
Originally Posted by KPierson
The car in question is a 2004 Infiniti G35 coupe (owned by me). Basic mods include:
8.6:1 Arias pistons
Pauter rods
Koyo radiator (350z conversion)
JWT cams
JWT valve springs
APS TT (350z conversion
Custom 1 of 1 front fascia for APS FMIC
APS test pipes
APS dual exhaust (350z conversion)
KPtechnolgies stealth shift light (blue for now, white soon)
Crawford cast plenum
Custom return fuel system
Walbro 255lph fuel pump
Samco hoses
ARP stud kit
KPtechnologies OEM window up module
KPtechnologies remote sunroof module
KPtech Nav 'OK' bypass
KPtech auto lock with speed switch
KPtech Fog light switch integrator
Thats just to give you an idea of what you are listening to while the video plays and has nothing to do otherwise with this teaser video.
The video shows KPtechnologies latest creation, still in the EARLY stages of development. Finally got a working prototype in my car, but it is JUST a prototype and the final version is still at least two months away.
Anyway, enjoy the .avi (its ~5mb)
http://www.KPtechnologies.com/movies/mirrormod.AVI
Also check out: http://kptechnologies.com/forums/vie....php?p=749#749 for more specific information!
Old Jan 30, 2007 | 06:55 PM
  #115
KPierson's Avatar
Getting close!
http://kptechnologies.com/forums/vie...hp?p=1346#1346
Old Apr 18, 2007 | 03:18 PM
  #116
GreenGoblin's Avatar
The goblin resurrection
very cool glad to see this moving on
Old Apr 18, 2007 | 03:53 PM
  #117
redlude97's Avatar
does it work for both left and right mirrors?
Old Apr 18, 2007 | 04:57 PM
  #118
KPierson's Avatar
One module controls one mirror. It is possible (and very easy) to install a 2nd module to control the left mirror.
Old Apr 18, 2007 | 08:55 PM
  #119
redlude97's Avatar
Maybe I should clarify my question, with 1 module, can it control both mirrors at seperate times, based on the settings of the stock selector, or will I have to choose a side to install the module on, ie there are seperate wires for left and right side mirrors
Old Apr 18, 2007 | 09:29 PM
  #120
afr0puff's Avatar
Supa Dupa Moderator
Release date in sight?
