Pics of my Kenwood DDX-8017 - not 56k friendly
Old Mar 15, 2006 | 02:34 AM
MikeyMike's Avatar
Rollin On Dubz
How much did that unit set you back Lazee? If you don't mind me asking
Old Mar 15, 2006 | 02:48 AM
imalazeeass's Avatar
it was about 1150 with tax in cali. got it from onlinecarstereo.com
Old Mar 15, 2006 | 03:25 AM
MikeyMike's Avatar
Rollin On Dubz
Not bad at all...
Old Mar 15, 2006 | 12:03 PM
BadCommand's Avatar
Originally Posted by imalazeeass
thanks so much for your reply, that was very helpful. So the only way to only use the highlight function is to disable the remote all together?
and yes i did get the pac unit but i have not gotten it to work yet. It is halfway connected (about 90%) the only thing missing is the power wire which we couldnt figure out at the time. Could that be a problem why the remote doesnt work?
you should be able to use both the touchscreen and the remote for the highlight function. I'm not sure why your remote is not working as I'm using the PAC ALP and my remote as well with no issues, but I'm not sure what effect a PAC that is not fully hooked up would have on the IR remote. a easy way to add that power for the PAC ALP is to just get a "ADD-A-CIRCUIT" - it's a real easy way to add a ignition switched power line- i get mine from parts express but i think autozone has them as well.
Old Mar 15, 2006 | 01:54 PM
SI_G35Coupe's Avatar
those that are using the PAC ALP.... does this allow you to use ALL of the steering wheel controls with the Kenwood? and is there any kind of delay like when using the PAC SWI-X?
Old Mar 15, 2006 | 09:00 PM
TheDoG35's Avatar
I hooked up the PAC ALP unit. I need to do a little fine tuning I think , but it is handling the volume and that's the steering wheel control I use most of the time. I don't think the Kenwood unit will accept the power on/off through the steering wheel, I have that one set to 'attenuate', I use that more that power on/off anyway. 'Mode' works fine, though there's a lot of 'modes' on this unit (AM/FM/DVD/video/Sirius/external media/cd/?). The track up/down works in all the modes I can remember checking it.
Delay-wise, the volume control is not quite as responsive as the OEM unit/steering wheel control, or the control on the kenwood unit itself, but in practice I've not had any trouble getting used to it. Can't compare it to the SWI-X since I've not tried that.
Old Mar 15, 2006 | 09:05 PM
TheDoG35's Avatar
yea it was way too thick, how the heck did you get it on?
I trimmed it down some, but ended up leaving it as you did, looks far better without than with. But one of my next projects might be to try and get a little artistic with some black plexiglass. I'll post pictures if I can produce anything that's not too embarrassing.
Old Mar 17, 2006 | 10:27 PM
well i got the new remote and it still doesnt work. Defective headunit? LOL. Im about to give up. SCREW THE REMOTE!
Old Mar 20, 2006 | 02:37 AM
escobar929's Avatar
what happend to the pics?
Old Mar 20, 2006 | 02:48 AM
BigSash's Avatar
+1 wtf pics aren't displaying
Old Mar 20, 2006 | 02:49 AM
LOL my host exceeded daily bandwidth. Sorry guys check back later
Old Mar 20, 2006 | 12:22 PM
BigSash's Avatar
HU install looks clean. Did you inspect the IR receiver for the remote? maybe it is obstructed or something.
Jessica Ayoub
Oct 17, 2015 02:01 PM
R350k5
Oct 1, 2015 08:41 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
