My PS2 to TVANDNAV2GO to PA11-NIS
Old Mar 26, 2006 | 07:26 PM
Real_G's Avatar
An Army of One...
Well, just finished and it works fine!
PS2 running into the TVandNAVtoGO PNP module. and the audio running into the AUX on the PA11-NIS. Sounds and looks awesome!
Still have to find better wireless controllers, or clean up the wires on the controller.. it does close but with some extra effort.
Took about 3 hours.. hard wired a inverter, replaced the switch to a rocker switch and mounted next to the bass control ****.Cut up the glovebox.
And installed the NAV bypass module!
Will post more pics tommorow, I took these in the dark...
Old Mar 26, 2006 | 08:19 PM
vrsc's Avatar
Nice Job
Old Mar 26, 2006 | 08:22 PM
GLuXuRy's Avatar
Sweet !!! Entertainment for the passenger... or driver when stuck in full on stopped traffic !!
Old Mar 26, 2006 | 09:04 PM
SFLG35's Avatar
FGC President
looks good.
how big a hole did you have to make for the ps2 power cables??
can you shut it with the remote connected??
if you can what about when you have a memory card in there??
if so what memory card are you using and where did you buy it cause i need one!!
i can shut mine with the controller connected but not with a memory card.
Old Mar 27, 2006 | 02:31 AM
nm3th's Avatar
What material did you use for your ashtray switch panel?
Old Mar 27, 2006 | 03:08 PM
Real_G's Avatar
An Army of One...
Originally Posted by SFLG35
looks good.
The outside hole is about 2.5" X 3" then the hole in the glove box is just slightly smaller.
Yes, I can shut it with remote connected. I had to cut and bend the wire on the plug for the IR reciever.
No memory card found yet..
The swithes/**** are mounted on a simple piece of plastic.. nothing special.
Old Mar 27, 2006 | 03:46 PM
SFLG35's Avatar
FGC President
yeh thats about how big my whole is
who makes aftermarket memory cards for ps2??
Old Mar 27, 2006 | 04:03 PM
KrazyEd's Avatar
looks good, nice job!!
Old Mar 27, 2006 | 04:12 PM
dofu's Avatar
20 Year Member
How did you get all the wiring in the back to fit? Did you hardwire it all to the PS2?
Old Mar 27, 2006 | 04:29 PM
Real_G's Avatar
An Army of One...
No, its plugged in... most of the wire is tucked away in the cavities of the car. I left just enought to go to the PS2. Had to keep taking it out and making the hole bigger.. until it worked.
Old Mar 27, 2006 | 04:51 PM
dofu's Avatar
20 Year Member
I wish I can get pics of my power cable and video cable on the PS2 side, but it's all hardwired to the PS2 board so it would fit without too much hassle...
Old Mar 27, 2006 | 04:53 PM
Stroked & Blown's Avatar
That video quality looks a lot better than my AVElectronic unit.
Old Mar 27, 2006 | 04:56 PM
cyberz350's Avatar
Hey how's it going. Is there some thread or website I can read more about this TVandNavToGo unit? I've got a friend that wants to put an Xbox into his G.
Old Apr 11, 2006 | 06:13 PM
Strtsk8r321's Avatar
How do you change to the aux input (which in you case is the PS2) on the PA11-NIS?
Old Apr 11, 2006 | 07:07 PM
Real_G's Avatar
An Army of One...
I installed a rocker switch.. to flip between the NAV and PS2.
