Nuvi 350 hardwiring
Old Mar 31, 2006 | 11:39 PM
sd_diver's Avatar
Nuvi 350 hardwiring
Okay, I'm really happy with my Nuvi 350 - to the point that I want to hard-wire it into my car. So I contact Garmin to see if they have an appropriate cable. Their response is that hard wiring it would void my warrenty. Huh? Any way, the connector is a fairly standard mini usb. The car adapter outputs 4.5V, while the power outlet is 12v. What would be the best way to drop this 12v down to 4.5 - 5v?
Thanks!
sd_diver
Old Apr 1, 2006 | 11:30 AM
Motown_Hog's Avatar
Can you post pics of where you have it installed?
Old Apr 2, 2006 | 06:26 PM
cavu's Avatar
I don't have an answer on the wiring, but here is a thread where someone has given up trying.
http://www.gpspassion.com/forumsen/t...TOPIC_ID=52032
Good luck.
Old Apr 2, 2006 | 08:31 PM
bstall's Avatar
here is an easy way to do it. Buy the adaptor from the link and wire it to 12 volt switched and ground. then you can keep the factor garmin plug in one piece and just plug it into the new socket and hide it behind the radio, under the dash or wherever.
http://www.myradiostore.us/power-acc...t-adapter.html
Old Apr 3, 2006 | 02:56 AM
sd_diver's Avatar
I think it is time to go the hidden socket route as well. Now to go and find an addl 12v garmin cord.
Thanks for the input!
sd_diver
Alex Koss
Oct 29, 2021 12:53 PM
g.spot
May 9, 2016 10:54 PM
rob dog g35 cpe
Lights
Apr 12, 2016 07:02 PM
shavedcrx
18 Inch
Dec 29, 2015 07:39 AM
Kicknshift
Sep 3, 2015 09:35 AM
