My new sub enclosure
Originally Posted by Steel Blue
Do you have any pics of this?
So if I understand you correctly, you are still using the OEM amp and you added this new one?
Depending on the amp you might need a line level converter.
Any experienced installer should be able to accomplish this.
i got 3 8" w7s. ya they r loud. i like them a lot. go check them out on my cardomain. sry dont kno how to post pics lol.
http://www.cardomain.com/ride/2290081
looking good...you should also post you install and specs in this sticky thread:
https://g35driver.com/forums/audio-video-electronics/91773-custom-audio-system-gallery.html
First off, great job on the install. I have a few q's for you. I am in the process of beginning to start my system and have been leaning towards either two 8w7's or 8L7's. I was planning on building a box much like yours and would like to know what kind of volume you acheived with it. If you had a picture of the box from the reverse side that would be great, or even some dimensions. Thanks
Thanks man. Here are some pics that I hope will help you.
Pic 1. Rear of enclosure. I did not want anything fancy no one will see it.
Pic 2. Taking apart multi piece trim piece.
Pic 3. Trim piece off.
Pic 4. Hidden sat. radio antenna. Your antenna does not need to be outside the car.
Pic 5 . All together.
Enclosure is .90 cubic feet total volume. It is stuffed with poly fil.
Hope it helps.
Hope it helps.
FS[SoCal]: D/S 4080 Enclosure & JL Audio W6v2 10 inch
MrIP35
Audio/Video/Electronics
11-08-2015 10:47 AM
