Yet another stock HU Question... Help...
Okay, I'll help you here but seriously, search Bose and JL amp and you will find this info.
The wire colors were posted above.
The stock bose head unit send out a flat (for the most part) balanced differential signal to the Bose amp in the trunk. You can tap this signal just before it reaches the amp and use that as your input. Since the JL Slash series amps will accept balanced differential inputs you don't need any LOC's. The singal from the stock HU is a 4V singal that you can directly feed into your RCA inputs on the amp. You will need to find a twisted pair RCA cable with male ends and do some cutting/splicing into the stock wiring and that should be it.
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Tonka211
Sep 18, 2015 09:46 AM
