Anyone install shock sensor add-on to an 06 yet?
Old May 1, 2006 | 04:18 PM
johnadlertech's Avatar
My harness as 5 wires. A pink, white, green, red, and red-white.
Old May 1, 2006 | 09:07 PM
And here are some crappy pictures. I guess I will try the red & white wire next. I just hate to keep hacking into the harness.
Attached Thumbnails Anyone install shock sensor add-on to an 06 yet?-img_0368.jpg   Anyone install shock sensor add-on to an 06 yet?-img_0371.jpg
Old May 1, 2006 | 09:50 PM
SFLG35's Avatar
FGC President
are you letting the alarm arm???
Old May 1, 2006 | 09:54 PM
SFLG35's Avatar
FGC President
sit in the car with the door shut
lock the car with you in it
your security led will come one solid after you lock the car.
after 30 secs it will start blinking.
when is starts blinking tap the shock sensor and see if it goes off
do not tap the shock sensor when the security led is blinking or it will disable the alarm.
Old May 2, 2006 | 02:29 PM
I really appreciate the help, but it seems like you contradict yourself here. Or did I just not read it right.
What I have done.
I wait 30 seconds after arming, Infiniti LED starts blinking. I tap shock sensor, its LED lights but no alarm. If I open trunk (actually I pull the emergency open handle, while the trunk is open but locked) the alarm does go off. So assuming I did tap into the right wire, its signal does still go through the hook up. Since I used connectors I will try forcing the trunk alarm with the wires split. If the alarm still works I have the wrong wire, or if other trunk features dont work same thing. So it appears that that harness is diffrent between the 03, 05, 06 (or intellikey?). Was your 05 the same wiring as mine (five wire)? Thanks.
Old May 2, 2006 | 02:34 PM
SFLG35's Avatar
FGC President
yeh i ment to stay
when the security led is solid dont tap the shock sensor cause it will disable the alarm
Old May 2, 2006 | 09:04 PM
Still cant get it to work. With the solid Red wire I used disconnected the trunk alarm still goes off. so I dont know what that wire controls. The dash trunk switch still works, but the trunk light does not seem to be working with the wire disconnected or tapped into the sensor. I will have to wait until I get some more connectors before I try cutting the white/red wire.
Old May 2, 2006 | 10:16 PM
SFLG35's Avatar
FGC President
try this
strip a little bit of the insulator of teh red white wire off
then take a wire that is connected to ground
after the alram has armed take teh wire that you connected to ground and touch it to the bare spot in the red white wire. if the alarm goes off when you do that you have the right wire
or take your dmm connect the black end to ground stick the red end into the red white wire and then pull the emergeny release. if the wire goes to ground when yo do that its the right wire.
if anyone has an 06 service manual could you please send it to me so i can find the correct wire quicker and easier
thanks
Old May 2, 2006 | 10:17 PM
SFLG35's Avatar
FGC President
john feel free to contact me on aim sn is over here -------------------------------------------------------------------------->
Old May 3, 2006 | 12:46 PM
Thanks. I probabally wont have time to work on it again until the weekend.
Old May 6, 2006 | 09:55 PM
So I used the red & white wire just like it said in the directions. And it worked. So basically I read this thread a few days early. I dont know on the 05 & 06 listed, but on my 05 G35x (early production I have been told) the standard hook up works just fine. But thanks for the help. All the harnesses look a little diffrent.
Old May 7, 2006 | 10:59 AM
SFLG35's Avatar
FGC President
sweet so you got it working!?
Old May 8, 2006 | 12:58 PM
yep. Not as sensitiave as I want, but later I will try and make the sensor more "dangling". But thanks for the help.
Old Jun 13, 2006 | 03:03 PM
Derzigster's Avatar
What is the model of shock sensor that people are using with the stock alarm?
Old Jun 13, 2006 | 09:52 PM
  #30
redwillow's Avatar
20 Year Member
complete info here, dei 504m was the orig, but they might have a newer one out with a switch now
